battery relocation
Old Apr 14, 2006 | 03:29 PM
Ph4tty's Avatar
battery relocation
Well I got my parts put together for my planned intake and it looks like the only way I'll get it to fit is to relocate the passenger side battery. What would be involved in relocation? What's the normal solution for guys building compunds?
Old Apr 14, 2006 | 09:30 PM
moparguy's Avatar
I put my truck on one Exide gell pack battery back in 03, no problems yet. Without checking, I think it's 950 or 1000 cca's.
RR
Old Apr 15, 2006 | 04:32 AM
Tiny Ram's Avatar
Where do you want to relocate it too?
If it's going to be any distance (say to the bed) use HUGE cable. 0/1g welding cable works great and is well shielded. Also, if you move the batt that far ground it with a big braided strap. As well replace the grounding cable from the alternator with 0/1g as well to prevent charging issues.
Depending on how it's setup you may need/want to change how the starter is wired.
Old Apr 15, 2006 | 12:38 PM
Ph4tty's Avatar
I'm thinking it'd be easier to switch to a good single battery like an odyssey, but what do you do with the old terminals and the other wires?
Old Apr 15, 2006 | 03:29 PM
ncmech's Avatar
Stay with dual BIG batteries. You can get all the air you will need without moving that battery out of there.
Blueboy
Apr 30, 2010 02:07 AM
Bluedually4x4
Jan 4, 2009 12:31 PM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
