bad compression??
Old Feb 8, 2011 | 08:59 PM
DC199512V87's Avatar
bad compression??
when i park my truck facing uphill and leave it in like 2nd or 3rd gear, it slowly rolls backwards. and its not a very steep incline at all. does this mean that iv got leaking compression somewhere? makes me use the parking brake which i does like when its -30 out in case it freezes up.
Old Feb 8, 2011 | 09:08 PM
Purplezr2's Avatar
Sure the clutch isn't slipping, have you tried 1st.
Old Feb 8, 2011 | 11:55 PM
Tate's Avatar
If your compression is that low, it likely wouldn't run. Most gas engines are only 8-10:1 compression, and they hold trucks fine in gear. Your truck won't run on that low of compression.
Old Feb 9, 2011 | 11:54 AM
infidel's Avatar
I learned to always park in 1st or R and have never had one roll.
Old Feb 9, 2011 | 06:13 PM
clutch is good as new. i will try 1st or Low gear and see how that works. thanks for the help....just trying to stay one step ahead in case it was starting to go...... lol
Old Feb 11, 2011 | 11:05 PM
totalloser's Avatar
The only thing that really holds the truck when in gear with the parking brake off is the friction of the running gear multiplied by the gears along the way. Not the compression. The compression easily escapes out of the engine-just not very quickly. That's why you can turn the engine over with a breaker bar.
The compression sneaks past the rings just as blowby does, and that's only the cylinders that happen to be HOLDING compression at any given time. IE most are not on a compression stroke at any given time.
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
SjLingenfelter
Jun 30, 2003 01:35 PM
