Aux. Reverse Lights
as for the blown fuses mentioned earlier in the thread . . . found to problem a while ago. when i had the airbags put on one of the washers on the inside of the framerail had a wire slip under it before getting fastened down - when it was tightened up it broke the wire insulation creating a short. fixed now, and re-ran power supply the wires with 12g instead of 16g.
Another question for you all; when I go in reverse my stock backup lights only come on if the gear selector is between P and R; not directly on R like it should. Is the adjustment for the switch in the steering column or on the linkage?
Thanks,
Thanks,
tntshrekuk
Jun 25, 2008 12:02 PM
Hercules130
May 31, 2006 08:58 AM
Blast54
Nov 2, 2003 01:46 AM
