Autometer Pyrometer in! Needle Sticks...
Old Jul 26, 2006 | 11:20 PM
wcbcruzer's Avatar
I just got done installing my Autometer ultralite pyrometer and took the truck for test drive. Unfortunately, the needle sticks a little. For example, it would suddenly jump from 400 to 600 degrees. But it does respond well, just not smooth. I'm guessing the gauge is bad?? Anyone else with an Autometer experience this?
Now as far as egt's... My truck is completely stock. Accelerating a little fast from a red light to beat normal traffic, with the boost going up to 15 psi, I can reach 825 degrees pretty easy. I hit 600 degrees with no problem, even driving it easy. Then later as I let the truck idle to cool off before I shut it off, it took about 2 minutes for it to go from 400 to 300 degrees. I have the probe mounted pre-turbo, about 2" towards the engine from the gasket where the exhaust manifold connects to the turbo. Also, I put the probe a little closer to the front of the engine (piston #1). These sound right? The needle was pretty responsive. Got to 800 degrees in a few seconds when I got on it...
Old Jul 26, 2006 | 11:42 PM
oestreich84's Avatar
Your temps seem normal, but the gauge shouldn't stick. It should be nice and smooth. I would call the place that you bought it from and go from there.
Old Jul 26, 2006 | 11:43 PM
Viperdew's Avatar
I have autometer ultralite gauges in my truck but didn't have problems with the pyrometer. I had problems with my boost gauge and called them directly in which they replaced no questioned asked. Check to make sure all of your wiring is grounded correctly. If so I would exchange the gauge for another one. Like I said above I have had only one issue and it was with my boost gauge sticking.
Another thing is does it work correctly at night? Should not matter with the proyometer but with my boost and the temps in the truck were about 112 degrees it would stick but since I got a the new one never a problem.
Call Autometer Directly - if you have a receipt they will do a full no question asked replacement.
Old Jul 26, 2006 | 11:50 PM
wcbcruzer's Avatar
Yeah, grounds seem to be ok and it still sticks in cooler ambient temps. I'll call Autometer tomorrow. It'll be good if they could just replace the gauge like you said. I don't feel like pulling the probe out, which I think is fine. But the thing is, I bought it off ebay. It was brand new, so I hope Autometer doesn't give me cr@p about that...
Old Jul 27, 2006 | 12:28 AM
Viperdew's Avatar
Here is the e-mail when I received when I sent my Boost Gauge back:
I am sorry but there is not much that I can advise unless we are able to take a look at it. I would recommend that you send your gauge into us, and if found to be defective or out of calibration we will repair or replace at no additional charge. Please send your gauge to the following address:
Auto Meter Products
ATTN: Service
413 W Elm St.
Sycamore, IL 60178
Please include your name, address, daytime phone number, and a description of the problem. Also, include a photo copy of your receipt for warranty purposes.
Thanks,
Tech/Service
Give them a call and everything should work out okay!
Old Jul 27, 2006 | 12:46 AM
texaspower19's Avatar
ive got the same gauges and mine did that stick stuff at first and now it just wobles were ever it wants too
Old Jul 27, 2006 | 09:07 PM
lezmark7's Avatar
Pyro bounce
Before mine got permanently stuck it did just that. I sent it back and they sent me a brand new one - no questions asked!
Old Jul 28, 2006 | 08:35 AM
Gotlift01's Avatar
I have the same problem with mine, same gauge as you!!! It's done it since day one......I've just gotten used to it. I was gonna send mine back until they said " please send your receipt "......... I don't have mine anymore!!
It reads accurate, but doesn't do a nice smooth sweep, jumps from temp to temp.......little annoying but like I said I just got used to it.
~Nick
Old Jul 28, 2006 | 10:53 AM
HOHN's Avatar
Don't mess with the people you bought it from. Go to Autometer. They have good customer service. When my Ultralight Pyro died, they sent me an NV series FOR FREE!!! Much better guage, imo...
jh
Old Aug 11, 2006 | 02:38 PM
wcbcruzer's Avatar
Alright got a free factory re-furbished replacement for my damaged gauge straight from Autometer. Great customer service! However, they forgot to send the little, black light bulb fixture with the new gauge... I emailed them about it. So now I gotta wait for that to arrive, if they send it ...
Old Aug 11, 2006 | 03:23 PM
Gotlift01's Avatar
Well update on mine..........IT DIED!!! Driving home from Denver the other day and notice my needle pointing down towards my feet.......guess it decided it didn't want to work anymore!!!
~Nick
Old Aug 13, 2006 | 02:22 AM
wcbcruzer's Avatar
~Nick
That sux... I'd still send Autometer an email. They will probably still replace it. I told them I got it brand new off ebay and they didn't ask me for a receipt or anything. If you end up sending it, make sure you send ONLY the gauge... No light bulb, screws, etc.
Old Sep 4, 2006 | 02:40 PM
wcbcruzer's Avatar
Now I think my boost gauge is starting to stick. Nothing major. But when I drive the truck for the first time of the day, the needle won't show 2-3 psi until I hit 4-5 psi. Then it starts working normal...
TJE
Nov 17, 2016 03:12 PM
Ronco95
Nov 27, 2007 07:32 PM
tomd
Dec 12, 2006 10:56 PM
Boatnik
Aug 21, 2005 11:56 PM
Green04HO
Jan 22, 2004 04:08 PM
