AutoMeter gauge fittings...
Old May 10, 2007 | 07:34 AM
CumminsRedneck's Avatar
Hey guys, i am just wanting to make sure that the fittings that come with the autometer gauges will work on my truck. Will the fitting that comes with my boost gauge work on my truck. Its a brass fitting. lol Has anyone used that boost fitting from the gauge and had it work?
Also, the fuel pressure sending unit. I got the electric gauge and this is simply a threaded both with a hole on one end and an electrical connecter on the other. Will this fitting screw into the bottom of my fuel filter canister?
I know the pyro. will work since i drill and tap that hole myself to whatever size is needed. My main concern if sor the boost gauge and fuel pressure sending unit.
TIA Guys
CR
Old May 10, 2007 | 07:52 AM
TonyB's Avatar
To connect the boost gauge: http://dieselmanor.com/dm_products/DM-BSTBLT.asp
To connect the fuel pressure: http://dieselmanor.com/dm_products/DM-DBBLT.asp
I used both of these products: They are top notch and make the install a SNAP!
HTH
Tony
ado2b1
Jul 6, 2007 10:27 PM
kawi600
May 4, 2006 09:43 AM
Dave88LX
Sep 11, 2005 09:26 PM
I PASS GAS
Apr 26, 2005 09:51 AM
TX Ram
Mar 16, 2003 06:01 PM
