ARP Headstud Torque???
Old Dec 3, 2006 | 10:37 PM
dodgediesel's Avatar
Question ARP Headstud Torque???
Has there been an update on the max torque on these head studs??? What is the highest torque I can give these studs???????
Old Dec 3, 2006 | 10:41 PM
Dshiftff's Avatar
for 12mm, 125ftlbs is usually good.
Old Dec 3, 2006 | 10:43 PM
Can I go higher???
Old Dec 3, 2006 | 10:57 PM
Cummins Freak's Avatar
why would you want to? you can go as far as you wnat but at a point your just weaking the actual stud
Old Dec 4, 2006 | 06:40 AM
BARTMAN's Avatar
Yes, a good bit higher. Do a search for an article penned by Don M, and read the research he did on a set of ARP head bolts.
Old Dec 4, 2006 | 06:58 AM
getblown5.9's Avatar
122ft-lbs with ARP moly lube, 130ft-lbs if you use just oil or some other lubricant.
when i did my final re-torque i actually went to 128ft-lbs with the moly lube and its holding great.
Old Dec 4, 2006 | 08:32 AM
Jetpilot's Avatar
You can go higher but its not adviseable.... The washers start crushing at around 122# with the ARP lube.
Old Dec 4, 2006 | 03:41 PM
I was wondering because I seemed to have lifted my head the other day while boosting hard! All of the sudden, my coolant tank spewed gylcol all over my engine and it must have got a big air bubble in the system. The heater would only blow cold air until I topped it up and ran the bubbles out! I'm guessing that's the problem. It is a new engine and the machine shop decked both the head and block. I have no other guesses as to why the glycol tank unloaded the glycol all over my engine so I thought I might try and tighten my head studs somemore...
The_Head
Mar 8, 2010 06:28 AM
jr22
May 22, 2007 11:49 PM
Rpainter
Mar 7, 2007 04:35 PM
bnold
28
Nov 9, 2006 03:25 PM
acook
Aug 29, 2006 10:08 PM
