ARP Head Bolt question..
Old Nov 29, 2007 | 12:10 PM
Muddin_dude06's Avatar
$4.95 each, wow thats not to bad! lol I didn't use any type of gasket sealer on the block but I have heard of some people using super high heat liquid copper sealent spread very thin over the block nice and even.
[/IMG]
Although that is a 24v head all the bolts correlate with the 12v and that is the sequence you want.
I would do 25, 45, 65, 80, 95, 105, 115, 125 in those incriments on the first torque (putting the head on). And then go in 5lb incriments after resetting them to 125 to what you want (I did 135lb) and take a break after each complete sequence.
Old Nov 29, 2007 | 01:40 PM
JD730's Avatar
Originally Posted by West Coast
Hey one other thing. I have done many heads on my chevy hot rods. Do any of the cummins head studs need sealant for water jackets?
Thanks..
All the holes are blind, no sealant is needed.
Old Nov 29, 2007 | 03:54 PM
kxhonda's Avatar
Hmm.. 26 bolts at 4.95... 128 bucks. Maybe I should try to buy them all seperate. Talk about retail markup.
Old Nov 29, 2007 | 04:14 PM
That probably doesn't include the nuts and washers though...
Old Nov 29, 2007 | 06:05 PM
West Coast's Avatar
My washers and nutz are good....... Hey I need some info on 60 lb valve springs. I am not sure if my last shop actually installed the 60 lb'ers or not. The machine shop asked for the spring pressure at installed height? Any help on this?
Old Nov 29, 2007 | 08:48 PM
Wow I don't have much of a clue on that one, you can somewhat identify 60lb valve springs because when installed they look like they "bulge" because the outside of them does not go straight down from the retainer like a set of stock springs do. Also they are longer when unistalled than stock springs. I will give Joe Hellmann a call in the morning and see if he can tell me the required spring pressure, that is if no one has the answer by then.
Old Nov 29, 2007 | 09:00 PM
elandon1201's Avatar
MY HG Just blew too!! I thought rings and studs would stop that
Old Nov 29, 2007 | 11:48 PM
Big Blue24's Avatar
Elandon, was your truck an HO or SO from the factory.
HRVP plus HOT Juice and big sticks equals a lot of timing. If your truck was an HO to begin with, that adds even more pressure to the HG and even more chance for leaks. What PSI was the silver gated to?
Old Nov 30, 2007 | 01:37 AM
West Coast's Avatar
Thanks for the help Mudd. I will post my question in the HELP section as well...
Old Nov 30, 2007 | 11:18 AM
MikeR's Avatar
Using calipers I measured stock 40lb spring wire thickness of .1845, and the wire thickness of the 60 lb spring of .188
The other was of visually looking at them. The 40 lb spring is the same diameter as the top retainer, where the 60 lb spring bulges out a bigger diameter than the top retainer.
Old Nov 30, 2007 | 07:29 PM
redneck_racer's Avatar
Sounds like some of you could use a new Head gasket. I have a 24V cometic Gasket that I am trying to get rid of. PM me if you are interested. It is brand new and I will sell it for 200 plus shipping
pwrtripls1
Mar 10, 2011 12:12 PM
Rpainter
28
Mar 24, 2008 01:39 PM
DMS1707
Sep 17, 2007 09:16 AM
97Dually
Sep 17, 2006 11:19 PM
Don M
32
May 12, 2006 02:37 PM
