Anyone install CAB CLEARANCE LIGHTS?!? PIC inside...
Old May 20, 2005 | 03:59 PM
wcbcruzer's Avatar
Hi, I'm going to be installing some cab clearance lights on my truck soon but I don't have a template. I was just wondering if anyone has done it themselves, maybe you can take a look at this pic and tell me if these are the right holes to drill for the lights. Thanks!
Old May 20, 2005 | 06:42 PM
12vordie's Avatar
I helped a friend of mine install a set on his '98 3/4t that came from the factory without them. The only holes we had to drill where on the outside of the cab, for the wire and screws. He bought his clearance light kit from the dealer for around $145.00 and it came with the template that you lay over the top of the cab.
Old May 21, 2005 | 01:12 AM
wcbcruzer's Avatar
Hmm.... So you don't remember whether the holes you drilled on the outside of the cab ended being in the exact same position as the holes I circled in the pic?
Old May 21, 2005 | 02:10 AM
wcbcruzer's Avatar
Can someone do me a favor and just make a real quick measurement from outside the cab? If you can give me the measurements from the top of the windshield to the center cab light (1), further out cab light (2), and furthest out cablight (3) that would be great! Below is a pic of what I'm talking about.
Old May 23, 2005 | 05:20 PM
mkubacak's Avatar
Here are my measurements.
1 - 5.125" from the where the glass meets the weather stripping.
2 - 5.25" same
3 - 5.625" same
Old May 23, 2005 | 11:15 PM
wcbcruzer's Avatar
Ah thanks. I went ahead and installed them yesterday anyway. Turned out pretty good. My measurements were about the same + 1.00".
Old May 23, 2005 | 11:33 PM
halerazor's Avatar
i have installed 2 sets and i always drill from the inside of the cab straight through the holes you had pictured thats what the holes are there for
Old May 24, 2005 | 06:23 AM
Valv's Avatar
Is the wiring harness there already or I have to run it from somewhere in the dash up to the ceiling ?
Old May 24, 2005 | 11:02 AM
halerazor's Avatar
hook it up to the back of the headlight switch . so when you turn your parking lights on they come on
Old May 24, 2005 | 11:40 AM
Valv's Avatar
Yes thanks but my question is:
Is the harness up to the roof already installed from factory or do I have to purchase it separate ?
Old May 24, 2005 | 03:52 PM
wcbcruzer's Avatar
It is not there already... If you have to make one, about 20 feet of 18 gauge wire from Home Depot will do.
Old May 24, 2005 | 08:53 PM
CODODGE2500MAN's Avatar
Wink
Halerazor is right on. Just installed mine in the 98 3/4ton and it works like a charm to drill from the inside out. Use that first hole for the wires and then measure for the other holes to make sure they are straight and even. Then Tap into the light switch. THey look awesome! Enjoy!
Ramcam
Apr 7, 2007 03:43 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
cummins dsl
22
Jun 27, 2005 11:53 AM
Nimrod
May 2, 2005 08:16 PM
Nov 23, 2002 07:35 PM
