Anyone dyno a combo like this?
Old Oct 24, 2002 | 07:04 AM
Timinva's Avatar
DTR Advertiser
Just installed my dd3 inj. a large difference from 275 rv's in smoke and power. I know you cant stack Hp #'s for add ons but was wondering if I was in the 325 hp range? What would the torque be roughly? My egts definately move higher and fuel press drops more [down to 9 psi at wot] than before. There are no dynos for diesels in my area. Thanks for any info. Tim
Old Oct 24, 2002 | 08:13 AM
PourinDiesel's Avatar
Re:Anyone dyno a combo like this?
Yeah,<br>I would say your in that area.<br>Every truck is different though, and so are dynos!<br><br>--Justin
Old Oct 24, 2002 | 08:36 AM
Timinva's Avatar
DTR Advertiser
I'm trying to work it in right now. It is 600 miles each way and Im getting married the following weekend. Been trying to get in all my bombing before than. Still trying to figure if I need the 4&quot; exhaust with dd3's. EGT is up to 1250 unloaded in 65f outside temps. I would love to go if for nothing else than to meet everyone and b.s. about our trucks. Will let yall know Tim
Old Oct 24, 2002 | 09:14 AM
StakeMan's Avatar
Weigh your truck. Go to a 1/4 mile drag strip and run the **** out of it. At www.prestage.com the is a car math section. Use your ET and weight. My 1/4 and dyno #'s have always been close.
Old Oct 24, 2002 | 10:47 AM
BigBlue's Avatar
The 4&quot; would probably help some. A scotty II would probably help more than the BHAF.
Old Oct 24, 2002 | 11:49 PM
Bart Timothy's Avatar
A 4'&quot; exhaust will not help you any. Spend your money on an EZ or Comp box first. A used EZ will be much cheaper and provide a much larger power increase than any 4&quot; system you could buy.
Old Oct 25, 2002 | 06:17 AM
Timinva's Avatar
DTR Advertiser
I already have an ez, waiting till I get closer to 100k miles to get the comp. I am not looking to gain any power w/4&quot; exhaust just lower my egt's. They are fine empty but if I tow they may get to hot. My fuel press at wot now drops to 7, is this a problem for a few seconds? These injectors put out a nice cloud of smoke when you want them to. Tim
Old Oct 25, 2002 | 08:23 PM
4 Tons-o-Fun's Avatar
I'd bet you're pretty close. With DD3's, an EZ and an HX-40 with the auto mine did 333.
Old Oct 30, 2002 | 12:16 AM
BigBlue's Avatar
When I said a 4&quot; would help some, I was talking about EGT's. Not power. Although, it did add a little to mine when I was bone stock (right down to the air filter). Maybe 5 to the wheels if that. Enough to beat up on a couple of stock PSD's that used to beat up on me.
Old Oct 30, 2002 | 02:19 AM
TxDieselKid's Avatar
[quote author=4 Tons-o-Fun link=board=7;threadid=6219;start=0#57658 date=1035595424]<br>I'd bet you're pretty close. With DD3's, an EZ and an HX-40 with the auto mine did 333.<br>[/quote]<br><br>that is odd, Evan Beck dynoed at 391 with an EZ and DD3's, with an HX35. Then again, he has an old set of DD3's, back when they were biggern then they are now.<br><br>andrew
Old Oct 30, 2002 | 05:26 AM
[quote author=TxDieselKid link=board=7;threadid=6219;start=0#59183 date=1035965987]<br>[quote author=4 Tons-o-Fun link=board=7;threadid=6219;start=0#57658 date=1035595424]<br>I'd bet you're pretty close. With DD3's, an EZ and an HX-40 with the auto mine did 333.<br>[/quote]<br><br>that is odd, Evan Beck dynoed at 391 with an EZ and DD3's, with an HX35. Then again, he has an old set of DD3's, back when they were biggern then they are now.<br><br>andrew<br>[/quote]<br><br>Well, Evan has a 6 speed and an HO. I have an auto and an ETC. But ETC's respond better to fueling boxes as was true in my case - did 490 with my FMS on.
Old Oct 30, 2002 | 08:33 AM
ROCKNRAM's Avatar
How about changing your turbo to get more air in. ???
kas83
Apr 8, 2008 11:15 AM
Jays98dodge
Jun 15, 2007 04:30 PM
whatdieseltoget
Nov 6, 2005 08:33 PM
Hoss
May 27, 2004 06:20 PM
