Any ideas on improving brakes on early 2nd Gens?
Old Oct 12, 2014 | 07:25 PM
Wobblin-Goblin's Avatar
I've got a '94 dually and even though it has an exhaust brake and new front rotors, pads, and one new caliper, when I tow trailers, no matter how cool or fresh the brakes are, I get the feeling they would be worthless during a panic stop.
Surely someone has come up with a way to improve these brakes. Anyone know how to?
Thanks.
Old Oct 13, 2014 | 06:04 AM
high bid's Avatar
Upgrading the rear wheel cylinders and making sure the rear brakes are adjusted properly will help some. Too much tow weight....do the trailer brakes work properly... May want to check them also.
Also, make sure there is no air in the brake lines and plenty of fluid.
Old Oct 13, 2014 | 08:00 AM
BADBOWTIE's Avatar
Any idea on part number for the upgraded wheel cylinders or what truck they come off of
Old Oct 13, 2014 | 10:42 AM
patdaly's Avatar
Here you go:
https://www.dieseltruckresource.com/...heel+cylinders
Old Oct 13, 2014 | 10:55 AM
When I did the brake job last year, I was surprised at the (lack of) size of the rotors and pads.
Old Oct 18, 2014 | 05:37 AM
jimbob1111's Avatar
I've been using Porterfield R4-S compound pads & shoes + the 1 ton Dodge wheel cylinder upgrade on my 96 2500 4x4 for years now. They have been the best money I ever spent on brakes for that truck! They work great hot or cold, good pedal feel, lots less pedal effort than before. If I stand on the brake pedal the truck tries to drop anchor as best a Dodge can! RWAL workn & front startn to lock up with 285/75-16 tires.
They have been real easy on the drums & rotors. I still have the factory drums & rotors @ 226K They said if I did mostly highway driving I should expect around 200K out of the rear shoes. Atlanta traffic can be hard on brakes. I do a pretty fair amount of towing & "I drive it like I stole it!"
At 72k I installed the 1st set of shoes, turned drums + 1 ton Dodge wheel cyl upgrade cause axle seals soaked everything with gear oil.
Put 1st set of pads on @ 76k.
At 210k, I replaced shoes, turned drums & put another set of pads on. They still had a "little" life left in them, but I don't wanna be thinking about spent brakes 1,000 miles from home.
We did the 1 ton Chevy wheel cyl 1-3/16? swap on Daniels 98 3500 V10 4x4 dually, but had rear brake lock up & grab @ parking lot speeds under light braking? Put Dodge 1 ton w/cyls back in and it went away?
I put EBC Green front pads on my jeep XJ, they worked good, once ya got a little heat in em! But ate rotors!!! and I had to holler "WHOA" & pull back on the steering wheel for that 1st cold brake stop with a trailer more than once.
Just my personal experience,
HMFG
Old Oct 25, 2014 | 09:09 PM
SIXSLUG's Avatar
If you have the hydro boost, you can upgrade to the 3rd gen rotors/calipers up front, but will need to find 17" or larger wheels to accommodate them....
Old Oct 31, 2014 | 11:02 AM
Midnite's Avatar
With a 1994 truck? I thought on those early 2nd gens the rotors were different and the 3rd gen ones wouldn't work.
Old Oct 31, 2014 | 06:18 PM
Danderson's Avatar
Yup,Dodge could have overengineered the 2nd gen brakes. What a great selling pt. "biggest brakes in the industry".
Old Oct 31, 2014 | 06:27 PM
Danderson's Avatar
Hydroboost came in in 1997 I believe.
www.egrbrakes.com might be able to help.
Old Nov 1, 2014 | 12:13 PM
BigIron70's Avatar
Cummins Guru
This was Chryslers answer to the problem
NO: 05-04-97
SUBJECT: Accelerated Brake Lining Wear, Front Versus Rear
DATE: Mar. 28, 1997
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 05-02-96 REV. A, DATED NOV. 15, 1996, WHICH SHOULD BE REMOVED FROM YOUR FILES AND NOTED IN THE 1996 TECHNICAL SERVICE BULLETIN MANUAL (PUBLICATION NO. 81-699-97010). THIS BULLETIN INCORPORATES THE USE OF REVISED BRAKE LININGS FOR VEHICLES EQUIPPED WITH 80MM FRONT CALIPERS. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS**.
NOTE:THIS BULLETIN APPLES TO 2500 SERIES AND 3500 SERIES RAM TRUCKS.
SYMPTOM/CONDITION:
Front brake linings wear prematurely when compared to the wear experienced on the rear brake linings. Normally, it is expected that the front brake linings will require replacement approximately twice before the rear lining assemblies will need replacement. The accelerated wear condition can be identified by requiring the front brake linings to be replaced four to six times before the rear lining assemblies are replaced.
DIAGNOSIS:
Review service history to determine if front brake lining wear has been accelerated, typically 3 to 4 times as often as the rear brake linings.
If the vehicle is a 2500 series, 8800 GVW, and is operated continuously near the Gross Vehicle Weight Ratings, have the vehicle weighed to determine if the loaded condition is at 75% or greater of the gross vehicle weight rating.
Visually inspect both front and rear brake assemblies for any signs of abnormal wear, abuse or mis-assembly of components. Refer to the appropriate Service Manual, Group 5, for information regarding service of braking components if the brake assemblies show signs of abnormal wear, abuse or mis-assembly of components.
If the front brake pads are evenly worn with the rear brake linings indicating light wear, perform the following Repair Procedure.
PARTS REQUIRED:
Quantity Part No. Description
**AR (1) 05003163AA 80mm Front Brake Lining Set, 2500 Series, 7500 GVW (All) And 8800 GVW 4X2**
AR (1) 04886279AA 86mm Front Brake Lining Set, 2500 Series, 8800 GVW, 4X4 And All 3500 Series Vehicles
AR (1) 04886328AA Rear Brake Lining Set, All 3500 Series Vehicles
AR (1) 04761560 Hold-down Spring Package, All 3500 Series Vehicles
AR (1) 04761603 Wheel Cylinder (27mm), 2500 Series, 8800 GVW Vehicles (Sales Code Z2B and Z7B)
REPAIR PROCEDURE:
**This bulletin involves replacing the front brake linings on 2500 series and 3500 series vehicles, the rear brake linings on 3500 series vehicles, and the rear wheel cylinders on 2500 series, 8800 GVW vehicles (sales codes Z2B and Z7B only) that are operated continuously near 75% or greater of the Gross Vehicle Weight Rating.**
Also, because rear brake adjustment is critical to the total operation of the braking system, it is recommended that the customer be made aware of the proper procedures to operate the rear automatic self adjusting brake system. The procedures are outlined in the Owners Manual. The procedure states, "To maintain the correct adjustment, you need only drive your vehicle in reverse and apply the brakes until the vehicle comes to a complete stop."
2500 Series, 8800 GVW Vehicles Only - Rear Wheel Cylinder Replacement
NOTE:THIS PORTION OF THE REPAIR PROCEDURE SHOULD ONLY BE PERFORMED IF THE VEHICLE IS A 2500 SERIES, 8800 GVW (SALES CODE Z2B OR Z7B) AND IS CONTINUOUSLY OPERATED AT 75% OF GROSS VEHICLE WEIGHT OR GREATER AS DETERMINED IN DIAGNOSIS STEP 2.
Be sure parking brake is released.
Raise the vehicle on an appropriate lift.
Remove rear wheel and tire assemblies.
Using tube nut wrenches, disconnect brake line from wheel cylinder.
Lift adjusting lever away from adjuster screw then, turn adjusting screw star wheel until screw is fully retracted.
Remove brake shoe return springs, adjuster spring, and adjuster screw. Move upper ends of brake shoes apart to provide removal clearance for wheel cylinder links.
Remove the rear wheel cylinder attaching screws and remove wheel cylinder from the support plate. Discard the wheel cylinder.
Apply thin coat of Mopar Silicone Sealer (p/n 4318025) to wheel cylinder mounting surface of support plate. Sealer prevents road splash from entering brake drum past cylinder.
Start brake line in cylinder inlet by hand. Do not tighten fitting at this time.
Mount wheel cylinder on support plate and install cylinder attaching screws. Tighten screws to 20 Nm (15 ft. lbs.) of torque.
Tighten brake line fitting to 13 Nm (115 in. lbs.) of torque.
Install brake shoe components removed to access wheel cylinder.
Adjust brake shoe to drum clearance. Refer to the 1997 Ram Truck Service Manual (Publication No. 81-370-7108), pages 5-40 and 5-41 "ADJUSTMENT WITH BRAKE GAUGE," for information regarding proper rear brake adjustment procedures.
Install brake drum.
Repeat steps 2 through 13 for opposite side of vehicle.
Fill and pressure bleed brake system with Mopar DOT 3 Brake Fluid (p/n 04318080) or equivalent.
Install rear wheel and tire assemblies and proceed to the next repair procedure. Refer to the 1997 Ram Truck Service Manual (Publication No. 81-377-7108), pages 22-8 through 22-10 for information regarding proper wheel installation and lug nut torques.
**2500/3500 Series Vehicles - Front Brake Lining Replacement
NOTE:THIS PORTION OF THE REPAIR PROCEDURE APPLES TO 2500 SERIES, 8800 GVW 4X4 AND ALL 3500 SERIES RAM TRUCKS BUILT BEFORE AUG. 5, 1996 (MDH 0805XX) AND 2500 SERIES 7500 GVW (ALL) AND 8800 GVW 4X2 BUILT BEFORE APRIL 7, 1997 (MDH 0407XX).**
If not already done so, support the vehicle and raise on suitable hoist.
Remove front wheel and tire assembly.
Press caliper piston back into bore.
Remove caliper mounting bolts with 3/8 in. hex wrench or socket.
Rotate caliper rearward off rotor and out of steering knuckle support ledges.
Remove and discard inboard brake lining by tilting the shoe at the top to unseat the retaining spring clip (Figure 1).
Remove and discard outboard brake lining by unseating the retaining spring on one end and rotating the lining out of the caliper (Figure 2).
Secure caliper to chassis or suspension component with wire.
CAUTIONO NOT ALLOW THE BRAKE HOSE TO SUPPORT THE CALIPER. SUSPENDING THE CALIPER BY THE BRAKE HOSE CAN DAMAGE THE HOSE AND FITTING JOINTS. USE WIRE TO SUPPORT AND SECURE THE CALIPER TO A CHASSIS OR SUSPENSION COMPONENT.
Clean caliper and steering knuckle slide surfaces with a wire brush.
Lubricate the caliper mounting pin and interior of bushing with silicone grease (Figure 3).
Install inboard brake lining from front brake lining set (see Parts Required section) onto caliper. Be sure the end of the retaining spring clip does not get jammed between the piston and the edge of the shoe plate (Figure 4).
Install outboard brake lining from front brake lining set (see Parts Required section) onto caliper. Be sure retaining spring ends are seated in dimples in caliper (Figure 5).
Install caliper over rotor and into steering knuckle mounting arms (Figure 6). Be sure caliper is seated flush on mounting arm surfaces as shown.
Start the caliper mounting bolts by hand to avoid cross threading then, tighten the mounting bolts to 51 Nm (38 ft. lbs.) of torque. Install tire and wheel assemblies. Refer to the 1997 Ram Truck Service Manual (Publication No. 81-377-7108), pages 22-8 through 22-10 for information regarding proper wheel installation and lug nut torques.
Pump brake pedal to reset caliper pistons and brake linings.
WARNINGO NOT MOVE THE VEHICLE UNTIL THE BRAKE LININGS HAVE BEENPROPERLY SEATED.
Check brake fluid level and add Mopar DOT 3 Brake Fluid (p/n 04318080) or equivalent if necessary.
If the vehicle is a 2500 series Ram Truck and the rear brakes were not adjusted from the previous repair procedure, adjust rear brake shoe to drum clearance. Refer to the 1997 Ram Truck Service Manual (Publication No. 81-370-7108), pages 5-40 and 5-41 "ADJUSTMENT WITH BRAKE GAUGE," for information regarding proper rear brake adjustment procedures.
3500 Series Vehicles Only - Rear Brake Shoe Replacement
NOTE:THIS PORTION OF THE REPAIR PROCEDURE APPLES TO 3500 SERIES RAM TRUCKS BUILT BEFORE AUG. 5, 1996 (MDH 0805XX).
Remove brake drum.
Remove primary (front) brake shoe return spring from anchor pin with brake pliers (Figure 7).
Remove primary brake shoe hold-down spring, pin, and retainers using a hold-down spring tool.
Disconnect shoe spring and remove primary brake shoe and parking brake lever strut.
Remove adjuster screw assembly.
Remove secondary brake shoe hold-down spring, pin, and retainer assembly then, remove adjuster lever, spring, and spring retainer assembly. It is not necessary to disassemble adjuster lever components unless they are worn or damaged.
Disconnect parking brake cable from lever attached to secondary brake shoe then remove brake shoe.
Remove and discard E-clip attaching parking brake lever to secondary brake shoe and remove lever.
NOTE:REAR WHEEL CYLINDER OR REAR AXLE SEAL SERVICE MUST BEPERFORMED PRIOR TO CONTINUING IF THERE IS ANY EVIDENCE OF LEAKAGE. REFER TO THE 1997 RAM TRUCK SERVICE MANUAL (PUBLICATION NO. 81-370-7108) PAGE 5-32 FOR INFORMATION REGARDING WHEEL CYLINDER SERVICE OR PAGES 3-87 THROUGH 3-152 FOR REAR AXLE SERVICE.
Clean support plate with Mopar Brake parts Cleaner (p/n 04549623). Then, smooth brake shoe contact pads with a wire brush or emery cloth.
Lubricate adjuster lever, anchor pins, and brake shoe contact pads with Mopar Brake Lubricant (p/n 04796269).
Clean and check operation of adjuster screw assembly. Replace assembly if threads are heavily rusted, corroded, or damaged. Make sure each screw assembly rotates freely then, lubricate the adjuster screw threads with Mopar Spray White Lube (p/n 04318066).
Attach parking brake lever to new secondary brake shoe (from p/n 04886328AA Rear Brake Lining Set). Use new E-clip to secure lever to shoe. If lever is secured with a U-clip, pinch new clip together with channel lock piers to secure it.
Attach parking brake cable to parking brake lever.
Install secondary brake shoe and adjuster lever as follows:
Insert new secondary brake shoe hold-down pin (from package p/n 04761560) through support plate.
Position secondary brake shoe on support plate and insert new pin (from package p/n 04761560) through shoe.
Position adjuster lever on brake shoe and insert new hold-down spring inner retainer (from package p/n 04761560) into lever and shoe. Inner retainer has a shoulder on it which seats in lever and shoe.
Install new hold-down spring (from package p/n 04761560) over pin and seat it in inner retainer. Then, install and seat hold-down spring outer retainer on pin with hold-down spring tool.
Install adjuster lever spring between brake shoe and lever. Be sure spring is seated on lever tang.
Attach shoe spring to secondary brake shoe. Long end of spring goes into secondary shoe.
Install oval shaped spring onto parking brake strut and engage spring end of strut into secondary brake shoe.
Install primary brake shoe (from p/n 04886328AA Rear Brake Lining Set) onto supportplate. Use new hold-down spring, pin, and retainers (from package p/n 04761560) to secure shoe. Be sure parking brake strut is seated in both brake shoes.
Install adjuster screw assembly. Be sure star wheel is positioned adjacent to adjuster lever and that notches in adjuster screw are properly seated on brake shoes.
Attach shoe spring to primary brake shoe. Use brake spring pliers and long screwdriver to seat spring in shoe.
Install shoe guide plate onto anchor pin.
Attach adjuster spring to spring retainer at the top of the adjuster lever then, seat spring on anchor pin with brake spring pliers.
Install secondary brake shoe return spring. Attach short end of spring to brake shoe then, hook opposite end on adjuster spring. Use brake spring pliers or a long shank screwdriver to engage return spring in adjuster spring.
Install primary brake shoe return spring.
Check component installation. Be sure adjuster screw, wheel cylinder links, and park brake struts are all seated in brake shoes.
Install brake drums.
Install wheel and tire assemblies. Refer to the 1997 Ram Truck Service Manual (Publication No. 81-377-7108), pages 22-8 through 22-10 for information regarding proper wheel installation and lug nut torques.
Repeat steps 3 through 31 for opposite side of vehicle.
Lower vehicle down and install any wheel covers that were removed earlier.
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Old Nov 22, 2014 | 07:38 AM
tighew32's Avatar
Brake upgrade
Thanks.
my name is Tighe I have a 1995 dodge 2500 with an 80 reared and as you say the braking sucked, however the guys at my local Napa turned me on to some wheel cylinders off of a dually Chevy that bolt right on and add 20 percent more braking to the rear axle. These work great. The Napa part number is 37337. Good luck I hope this helps you out. Also it was very cheap. I believe it was under 30 dollars!
Old Nov 22, 2014 | 09:24 AM
j_martin's Avatar
Jimbob,
do you have part numbers and source for the Porterfield Brakes?
Pull a lot, brakes are good, but don't last as long as I like. I drive pretty conservatively, and would like to have the feeling of excess braking available if needed.
Old Jan 6, 2015 | 02:32 PM
greasy's Avatar
CAREFUL in the snow!
truck is scary w/o a load on and braking in slick conditions...summer time it's fantastic with a load on..emergency braking in the summer and I've had the rears lock up and race the fronts down the pavement..that scared the crap out of everyone too.
Old Jan 7, 2015 | 07:53 AM
kawi600's Avatar
OR.. you can swap out the knuckles and hubs with a late 90's ford F250 dana 60 to get the manual hubs, larger rotors and twin piston calipers.
you can even ditch the !@#$!@# CAD if youre going full manual.
Theres a writeup on pirate4x4 about it someplace, but its pretty straightforward.
