Another stack question
I've always wondered if it was possible to run the y pipe under the bed instead of it showing in the bed. Has anyone ever seen it done? I think the install would look cleaner with just the stacks showing. thanks for any input.
From: Dayton, NJ (temporarily while In USCG on Staten Island)
y-pipe
Afternoon, well I just put in a set of stacks. I wanted to go under the bed with the Y-pipe, but would have ended up hitting the F/O tank. To tell you the truth, in the bed is not that bad. I am fabricating a box to cover the pipe and regain that part of the bed. Where are you located? I am in NJ, if not too far I could meet up with you to show you. I'll have pics soon here.
Stephen
Stephen
Detroit Diesel, I also am concerned w/ the issue of the pipes in the pickup bed and having to hide them with a conventional Delta-type pullup tool box. I've seen pics of toolboxes that fit right over the Y-pipe on one of the diesel websites. Is that a homemade job or is that something that can be purchased?
My second concern, is the fact of stacks being so **** loud that you will have to remove them. Can you or someone else give me advice/ suggestions on these issues before I saw a hole in the bed of my beautiful 01 ram 2500 and live to regret it? Thanks,
Pierce
Pierce
Ted Jannetty's shop does some nice stuff. Sadly, that stack system is probably worth more than my truck....
http://www.jannettyracing.com/images...y/stacks01.jpg
http://www.jannettyracing.com/images...y/stacks03.jpg
http://www.jannettyracing.com/images...y/stacks04.jpg
edit: I'd like to see a side view of that truck to see if the pipes hang down below the bedsides much...
edit_edit: I'd also like to see a heat shield on the pipe that runs in front of the tank
i have a buddy that ran the y pipe under the bed. but it was a long bed and never would tell me how they did it. all i know is it took them about a week to figure it out . would ask him again and take pics but he traded it in about 4 months ago
Jezzhuntin
Aug 25, 2006 02:51 PM
strokethis600
May 30, 2006 10:25 PM
blh1972
May 20, 2006 08:48 PM
White00
Nov 10, 2005 08:21 AM
