Another New B
Old Nov 27, 2005 | 11:16 PM
efrantz's Avatar
Another New B
I am Interested in turning my 2000 2500 cummins auto 4x4 into a real smoker that is also a great daily driver. I need a path and i need a plan. I want around 300hp and 500-600 torque is this reasonable to ask of a cummins with 120000miles on it already? What do i need to do as far as chip, intake, injectors, guages, TRANNY!, propane, what ever else. I Already have the 4" exhaust. I know nothing about diesels so talk slow.haha Thanks
Old Nov 27, 2005 | 11:20 PM
BigBlue's Avatar
Get an Edge EZ with a set of 275 injectors and you should be there. Fuel pressure, boost, EGT gauges. Scotty 2 intake system. That should put you at 300hp/600tq.
Old Nov 27, 2005 | 11:22 PM
efrantz's Avatar
Should i Worry about the miles or the trans?
Old Nov 27, 2005 | 11:25 PM
rebal's Avatar
A catcher(mad,ecm) mach1.6s ,intake exhaust and a built tranny ,gauges,and dont put anything on the dash, cuz it will be in your face!
and you will have tons of smoke if you want it
Old Nov 27, 2005 | 11:26 PM
BigBlue's Avatar
That combo there shouldn't strain anything. If you want, you can put in a new valve body from DTT and that will hold that combo with extreme ease. First things first though, get the gauges and get a base line. Your fuel pressure shouldn't be below 8psi at full throttle. If it is then replace the lift pump.
Old Nov 27, 2005 | 11:33 PM
efrantz's Avatar
What is A catcher(mad,ecm) mach1.6s. Likdea whe i said i am new and have no iat that is.
Ok i will set my base line before i put any of that other stuff on. what boost and egt should i have stock.
Old Nov 27, 2005 | 11:48 PM
rebal's Avatar
A catcher is a reflashed engine control modual brings all the timing and fuel in down low makes the truck feel like its 2x faster also gives about 66HP mach 1.6s are DON M F1 injectors about 90 hp above stock both give better perfor. and MPG
install all your gauges first to get a base line ....pyrometer pre turbo is the preferred location
Old Nov 28, 2005 | 12:17 AM
BigBlue's Avatar
A catcher with a set of mach 1.6's will have your tranny looking like it came out of mount saint helens.
Old Nov 28, 2005 | 12:22 AM
rebal's Avatar
BIGBlue you got me laughing hard on that one
True true you need a built tranny
HMX-1
Introductions / New People
Sep 19, 2009 08:24 PM
Ls1z28fbody
Nov 27, 2006 08:03 PM
snowrodeo
Oct 9, 2006 09:11 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
