which allison for a convertion?
Old Sep 19, 2006 | 05:00 PM
12valveford's Avatar
well I am gojn to be into the money a little (sho am I kidding a lot better) than what I am now, shortly
I want to convert to an auto
I was thinking (unless someone knows different(and I would enjoy the help))
that an allsion would be the way to go-
which would be the best and who make the adapters and electronic controls to run one?
and what do some of you guys use with a 5 or 6 speed auto as far as shifting options do?
Old Sep 19, 2006 | 05:20 PM
CTD_Neil's Avatar
Allison, Shmallison....Drop a Aisin 6sp auto in there.
Old Sep 19, 2006 | 06:32 PM
j-dubya's Avatar
if your set on the ally, id say do your best to get the new and improved version. get it with a stand alone computer and youll have a ton of cool features. not to mention two overdrives.
jeremy
Old Sep 19, 2006 | 06:38 PM
Tiger Rag's Avatar
A built 48RE by ATS, DTT, Goerend, Suncoast or the like would be a whole lot easier and equally, if not better hold the power. It'd probably cost less too and fewer gremlins to deal with.
Old Sep 20, 2006 | 06:36 AM
coalburner400's Avatar
The only Allison I'd consider would be a 2000 series.
I still think the build RE advice is the best advice. Its really an excellent trans once you eliminate a few points of failure (47 or 48 RE is what I'd go with).
Good luck
Old Sep 20, 2006 | 12:17 PM
well if I was to go with a built 48re instead
being I have 4:10's - what would be recomended for an overdrive?
Old Sep 20, 2006 | 12:38 PM
Bobcat698's Avatar
Allison 1000 series with the 6th gear activated would be SWEET. You would probably get close to the fuel economy of a truck with 3.54's!
Old Sep 20, 2006 | 12:52 PM
DL1221's Avatar
A Dodge 47 or 48RE will probably be an easier swap than an Allison. A solidly built unit from ATS, DTT, Goerend, or Suncoast will probably be about $4000-5000, if you get all the options. Don’t forget that, like the Allison, the 47/48RE is an electronically controlled transmission; so you will need to get the factory Dodge computer (PCM) and wiring harness/sensors to control it (assuming you don’t have it already in your Ford). I don’t know how much an Allison, with its stand alone controller would run, along with any adapter plates, etc.
Also, the Allison is a pretty big and heavy transmission, is it going to fit?
If you do go with the Dodge transmissions, both US Gear and Gear Vendors make auxiliary overdrives, they cost about $3000. I wish I had an auxiliary overdrive for my ’01 Dodge, it has 4.10 gears and it spins pretty fast at highway speeds.
Old Sep 20, 2006 | 01:20 PM
signature600's Avatar
Just go to 35" tires
Chris
Old Sep 20, 2006 | 01:50 PM
Gabe32's Avatar
Go with built 1000 series. I run it everyday and have sledpulled with it. You can't go wrong. Also you can get any 1000 series and get 6th gear out of it. I got the source for the standalone also.
Old Sep 20, 2006 | 08:39 PM
Gabe-
what did you do as far as shifting options
since all ford steering columns are 4 speed auto selectors
did you do some sort of slap stick?
Old Sep 20, 2006 | 09:44 PM
Gabe32's Avatar
i just used the stock dodge linkage and modified it. i can put it in all the gears except for first. If i really wanted to, I could do that too. It works great right now. It is exactly like the stock used to be, the right throw and everything.
Old Sep 20, 2006 | 10:51 PM
do you believe if I swapped out to an auto steering column of a ford - I could do the same then just modify the display?
Old Sep 20, 2006 | 10:59 PM
and how does it act with your 4:10's?
and fuel mileage?
oklahomaboy798
Nov 19, 2009 11:46 PM
bullfrog5.9
Oct 3, 2009 10:09 PM
bullboy85
54
Feb 8, 2008 02:22 PM
bullboy85
Dec 27, 2007 12:15 AM
steveooo
May 21, 2006 09:43 PM
