Allen wrench size for the transfer case drain?
Old Sep 27, 2006 | 08:13 AM
Tiger Rag's Avatar
Any one know the hex wrench size of the drain on the transfer case? It is magnum sized. I want to change my fluid but don't know which size wrench to buy. Thanks for the help, Matt
Old Sep 27, 2006 | 08:50 AM
B.A.Ram's Avatar
Matt, I'm pretty positive it's a 3/8... I changed mine not too long ago at 70,000 and it was still bright red...
Old Sep 27, 2006 | 09:32 AM
BigBlue's Avatar
Yah. It's gargantuan. Mine was ever so slightly brown and even then I think it was just the shadows playing tricks on my eyes. It had 70k on it also but it had been used many a times.
Old Sep 27, 2006 | 12:46 PM
H2SRDMB's Avatar
size wrench
3/8 does fit but i always use my crv-10 allen socket adapter. so ithink that means 10mm, little more snug fitting
Old Sep 27, 2006 | 01:03 PM
Tiger Rag's Avatar
Hmmm, Isn't a 10mm a good bit smaller? Eyeballing it, it appears much smaller. I figured it would be 17mm or more?
Old Sep 27, 2006 | 01:50 PM
HOHN's Avatar
17mm is the drain plug size on the NV5600. Is the t-case the same?
I thought the T-case was just one of those stick-a-ratchet-in-and-unscrew kinda jobs...(where theres a square drive of 3/8" or 1/2")
Old Sep 27, 2006 | 02:01 PM
RowJ's Avatar
It's big... but not a 'ratchet job'
I believe it is metric.... would not trust my memory in a million yrs to try and remember the size! I do remember it's the biggest in my metric set... which doesn't help you much.
Come on, somebody... go outside & measure it! I would if I had my tools with me... honest I would!
RJ
Old Sep 27, 2006 | 02:28 PM
Tiger Rag's Avatar
No it's a hex key screw and it is big. Fair question though since the oil pan is a 3/8 square ratchet drive plug. I do think you are right on the NV5600, I read the other day it was a 17mm.
I think my biggest is a 10mm and it wasn't even close. I even went to look at Harbor Freight the other day and their biggest was a 10mm. Figured I'd find the size before I went to Sears or elsewhere.
Old Sep 27, 2006 | 04:11 PM
HOHN's Avatar
RJ
Hey don't look at me-- my truck is 650 miles away and will be for a couple years
Old Sep 27, 2006 | 06:59 PM
Tiger Rag's Avatar
Wow, that sucks out loud. Sorry to hear that. I guess Honolulu can't be too bad otherwise though.....can it?
Old Sep 27, 2006 | 07:00 PM
Tiger Rag's Avatar
Anyone on the nightshift got any clue on the Allen wrench size on the transfer case drain and fill?
Old Sep 27, 2006 | 07:06 PM
Mountaineer's Avatar
just changed mine a hour ago and it is the number ten on the allen socket for the 3/8 rachet ( I think its mm) or whatever.
Old Sep 27, 2006 | 07:15 PM
TxDiesel007's Avatar
same with mine
it was a 3/8th
Rick
Old Sep 27, 2006 | 07:34 PM
Paintpusher's Avatar
10mm allen wrench
Old Sep 27, 2006 | 07:43 PM
Tiger Rag's Avatar
ok, I have to check my allen wrenches to see what my biggest is. I thought it was a 10, must be smaller. Thanks!
