Air Box
Old Jun 29, 2003 | 04:35 PM
bsummit's Avatar
Air Box
Going to purchase an air box and wanted some opinions from the pro's. What would be the best for the money. Going to change my turbo from 9cm to the 12 cm. Finally got the coins together. All suggestions appreciated.
Old Jun 29, 2003 | 04:41 PM
Monty's Avatar
Re:Air Box
Go with the ScottyII air system. http://www.wildcatdiesel.com
Old Jun 29, 2003 | 09:01 PM
Racer57's Avatar
Re:Air Box
Here we go again. Do it once, do it right. There is only one airbox to consider if you want cold air to your engine, and who doesn't. Scotty 2 and don't look back.
Old Jun 29, 2003 | 10:32 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:Air Box
[quote author=Racer57 link=board=7;threadid=16504;start=0#154805 date=1056938519]<br>Scotty 2 and don't look back.<br>[/quote]<br><br> Unless you're driving an 03. Then we'd prefer that you install the Ram Air III for the 2003 <br><br>Rod
Old Jun 29, 2003 | 11:38 PM
James Lucas's Avatar
Re:Air Box
Of course a Functioning Cowl Induction Hood Works well with K&amp;N AIR BOX... but then theres that stupid style issue!
Old Jun 30, 2003 | 12:14 AM
Scotty's Avatar
Top's Younger Twin
Re:Air Box
[quote author=JCL123 link=board=7;threadid=16504;start=0#154851 date=1056947935]<br>Of course a Functioning Cowl Induction Hood Works well with K&amp;N AIR BOX... but then theres that stupid style issue!<br>[/quote]<br><br>A functional cowl hood with twins and a custom intake is even better. ;D Not k&amp;n though.
Old Jun 30, 2003 | 07:53 AM
hellotbone's Avatar
Re:Air Box
[move]GET A CLEAR SCOTTY 2 ITS SICK!!! AND SUCKS COOOOOOOOOOOL AIR[/move]
Old Jun 30, 2003 | 08:44 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Air Box
[quote author=Scotty link=board=7;threadid=16504;start=0#154855 date=1056950087]<br>A functional cowl hood with twins and a custom intake is even better. ;D Not k&amp;n though. <br>[/quote]<br><br>HMMMMMMmmmmm......who would build such an item?........ :
Old Jun 30, 2003 | 10:28 AM
Scotty's Avatar
Top's Younger Twin
Re:Air Box
[quote author=Shovelhead link=board=7;threadid=16504;start=0#154944 date=1056980672]<br>[quote author=Scotty link=board=7;threadid=16504;start=0#154855 date=1056950087]<br>A functional cowl hood with twins and a custom intake is even better. ;D Not k&amp;n though. <br>[/quote]<br><br>HMMMMMMmmmmm......who would build such an item?........ : <br>[/quote]<br><br>
Old Jun 30, 2003 | 05:54 PM
cummingetit's Avatar
Re:Air Box
Dumb question of the day<br><br>How does everyone think the Scotty flows more air? Wouldn't it be the same as putting the little tube from the inner fender to the stock air box?<br><br>I know I have a lot to learn so please be gentle with me
Old Jun 30, 2003 | 06:02 PM
Shovelhead's Avatar
Re:Air Box
You forgot about the 4 1/2 inch hole into the cowl area.
The Scotty is not only about &quot;More Air&quot;, It's also all about......... (gotta say it)
CooOOooOOooOOooL Air ;D
It doesn't pull air from the hot area under the hood.
Old Jun 30, 2003 | 08:13 PM
Re:Air Box
Well I didn't forget about it. I just can't see making an unessesary hole in my truck. My argument was that just replacing the stocker with a Scotty, doesn't look as if it'd change anything (more air, cooler temps, etc.). What is the benefit without drilling a big hole?<br><br>I'm not saying the Scotty is junk or anything. I just would like to know what makes it so much better than the stock box, before I drop that kinda coin on air system.
Old Jun 30, 2003 | 08:41 PM
Scotty's Avatar
Top's Younger Twin
Re:Air Box
[quote author=cummingetit link=board=7;threadid=16504;start=0#155205 date=1057022035]
[/quote]
There are a lot of people that doubt how good it works.
Believe me if the stock box or any other system worked as well as this, I would be using the 'other' system.
Heres some info...think back to the reverse cowl induction cars like the Chevelle. At the bottom of the windshield there is a positive air pressure area forcing into the cowl.
IF you are running stock or near stock power...a factory air box is fine. However, once you start going over 300HP, you need more air and the Scotty does that...and its cooler outside air, not underhood air like 'other' aftermarket intakes can ingest.
So far the more power and load we throw at this system, the more effective it is.
I understand your concern and questions.
One thing I still do not understand is why there are some people out there that have never tried the Scotty II nor have they been in a truck with one and they STILL say it does not work like we and many many other people have reported.
I have often offered up the Scotty II for testing to the nay sayers and I rarely...very rarely get a reply via PM or email.
Go figure.
Sorry for the rant about that...it just baffles me how someone can comment on a products effectiveness and have never used it.
I am not implying this about you.
Without the hole you will still see better EGT reduction then a stock box...as long as you have at least 300HP or better. Most folks report 100-175F from stock air intake on 300-325 HP trucks with just the fender inlet in use.
I'd like to give another comparison here.
Why do people drop $400.00 or more on a four inch exhaust system for 50-75F EGT reduction but they are hesistant to spend half of the $400.00 to realize much more effective EGT reduction?
Of course one does have to address the exhaust after about the same level of HP where the Scotty II works...simply to assist in getting the air out more easily.
OK, I am done...hopefully somewhere in there I answered your concerns. ;D
Old Jun 30, 2003 | 11:46 PM
HeberRam's Avatar
Re:Air Box
My recommendation would be the Scotty 2.5 ...
I don't think even Scotty has seen this: :
http://www.dodge-diesel.org/yabbse/g...p&amp;pid=1992
Steve
P.S. better pic....and Scotty this isn't mine, saw this in Idaho. It's a Ram Air Scotty 2.5... : :
Old Jun 30, 2003 | 11:49 PM
Scotty's Avatar
Top's Younger Twin
Re:Air Box
[quote author=HeberRam link=board=7;threadid=16504;start=0#155292 date=1057034761]<br>My recommendation would be the Scotty 2.5 ... <br>I don't think even Scotty has seen this: :<br><br>http://www.dodge-diesel.org/yabbse/g...b_IM000368.JPG<br><br>Steve<br>[/quote]<br><br> <br><br>well?<br>results?
