aftermarket trans cooler will it help
Old Jun 13, 2004 | 12:52 PM
infidel's Avatar
Would you eat a cake that was only burned once?
The oil will not heal itself, some properties will be forever lost.
The numbers for synthetic are higher but the same applies.
Old Jun 14, 2004 | 09:04 AM
RowJ's Avatar
CrewCab
I agree with Bill. Changing it is cheap insurance.
Specific answer to your question might involve how long you stayed at 300* on your hard pull and how long ago you last changed your ATF. Definitely safer with synthetics.
Good indicator would be to wipe off dipstick with your fingers. Looking for any "burnt" smell. If you still have good red color and no odor, probably ok...but would still plan on shortening next change interval due to increased additive depletion. Good Luck!
Rowland
Old Jun 15, 2004 | 09:02 AM
CrewCabCummins's Avatar
Yeah... I guess i better change it... Oil is about 2 months old..AMSOIL.. The oil still look's and smell's like new.Both pull's was about 5 minutes long...
Old Jun 15, 2004 | 09:42 AM
TPilaske's Avatar
Amsoil claims their ATF "resists high temperature degradation three times longer" so I wouldn't dump it just because you hit a high temp once or twice!
I am running Amsoil in my Tranny and have pegged the gauge a couple times and the fluid still looks fine and, well, it always smelled nasty but does not smell burnt at all...
Tony
http://www.amsoil.com/products/atf.html
Old Jun 15, 2004 | 10:18 AM
Redleg's Avatar
I agree on the extra cooler first. The bigger pan next. Dont use the flat, pressed style cooler. It slows the flow and if your tranny does start to go, the debris will catch here, plug it up and kill it before you can get it home. Use the round, tube style. The larger the tube, the better. Get a gauge and mount the probe in the line coming out of the pump and before the cooler. Switch to synthetic too. Do all this and it will take some serious abuse to hurt it. Put synthetic in the diffs too. This will keep the temps down, yet lube quicker when cold.
Old Jun 15, 2004 | 08:49 PM
J BODY's Avatar
1st gen trans cooler. Found under the box side. Thermostatically controlled fan. We used to install them on 2nd gen too. Discontinued.
nfsommer
Nov 9, 2007 09:36 AM
95black2615
Aug 25, 2007 10:24 AM
EClancy
Jan 16, 2007 09:27 AM
live wire
Jul 21, 2003 07:26 AM
