ADT 4" 14ga. exhaust
I purchased the mufflerless 14 gauge 4" dia. system from ADT. It comes with a pre-welded rolled and polished SS tip. Here is the page: <br><br>Smokin Diesel <br><br>I installed the system by myself without a torch. I had to beat on the front hanger because they mouted it 3/4" too far forward. Including removal of the old system, the whole job took about 3 hours. Just used a die grinder with a cutting wheel, my impact and hand tools. I put band clamps at the lower downpipe joint and at the joint before the axle bend, so I can remove it if needed. <br><br>Had a slight drone around 2200 RPM. But I am used to it now. I will probably put some dynamat on the back cab wall and floorboard. <br><br>Sounds sweet! <br><br><br><br>
Re:ADT 4" 14ga. exhaust
me4osu, I am guessing getting the old one off was the hardest part of the job. Did the replacement fit well. How does it sound and how much did it cost?<br>inquiring mind wk<br>
The only hard part about the install was getting it to flange up to the turbo. I wish I had a torch with which to bend the mounting dowel instead of a 3lb go-easy. <br><br>It only took me an hour to get the old system out. Most of the time was trimming the last piece, making sure everything fitted up properly and cleaning up. <br><br>It sounds great. Also, I like that it is 14 gauge (more durable).
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
Hemlockusa
Jan 28, 2006 07:07 AM
