View Poll Results: Adrenaline tune
1000
6.00%
2000
18
36.00%
3000
14.00%
dyno
12.00%
comp
16
32.00%
Voters: 50. You may not vote on this poll
Adrenaline tunes
Old Jun 12, 2008 | 01:13 PM
ramcummins's Avatar
Adrenaline tunes
Which tune are you running?
1000
2000
3000
dyno
comp
I tried the factory 1000 tune for a few days then loaded the dyno tune yesterday. I will try that for a while to see how I like it. So far, so good.
Old Jun 13, 2008 | 12:12 AM
EBunger's Avatar
Just loaded the 2000a since I got my Pulse and it is the smoothest so far for sure. PL2 is like my Drag Comp on 3x5.
Old Jun 13, 2008 | 07:14 AM
dirtycj5's Avatar
i've had the comp tune in my truck for about a month i like it. very strong low end
Old Jun 13, 2008 | 11:39 AM
qzilla's Avatar
PL02 is just on the Can Bus!!
You don't even need to tap the wire for that level to work!!!
Old Jun 13, 2008 | 12:35 PM
cyric's Avatar
I am running the 2000 tune and I love it.
Joe
seth08's Avatar
i like the comp tune a lot better then any other 1 so far hooked with it last night got 299 feet
Old Jun 17, 2008 | 10:35 AM
ramcummins's Avatar
I just changed mine to the comp yesterday. It is a little jumpy, but it feels quite a bit stronger on the bottom end than the other tunes that I have tried (1000 and dyno).
Old Jun 17, 2008 | 11:36 AM
2whistlers's Avatar
I'm assuming that the ADR cannot be taken off like an '01 or '02 and put on say my '99 with just a map adapter? I realize this is a different box than most, but I was just curious. I have a guy that said he's got one stacked with a smarty which allows him 4000 rpm's. Anyone else having this kind rpm range or stacking the ADR? I realize the whole point of the ADR was to not have to stack, but if you can stack and get 4k then it definately seems worth it. Just curious.
Thanks
Old Jun 17, 2008 | 11:23 PM
J Lent's Avatar
ADR2000a here, a little shuddering going on, but I love it.
Old Jun 18, 2008 | 01:09 AM
EBunger's Avatar
Yes I agree the timing is a touch to much on the lower settings with injectors. But it doesnt hydro the injectors like the 3000 did to mine and seems smoothest otherwise on my truck.
Old Jun 18, 2008 | 07:25 AM
Tate's Avatar
For the ignorant or uninformed, whats the dyno tune about?
Old Jun 18, 2008 | 11:08 AM
2whistlers's Avatar
Nobody has answers to my questions???
Old Jun 18, 2008 | 07:02 PM
1badchopper's Avatar
The new comp is awesome
Old Jun 18, 2008 | 11:06 PM
qzilla's Avatar
2whistlers,
You can make it work but, you need to adapt the MAP sensors and you need to take the box apart and remove the jumper.
Old Jun 18, 2008 | 11:08 PM
Ramtuff06's Avatar
how does one get the comp and dyno tunes off quads site?
