Adrenaline Problems
Old Apr 12, 2009 | 02:12 PM
rholbus's Avatar
Adrenaline Problems
I lost the cable that connects my computer to the adrenaline and I have bought 3 other cables but when I connect any of them the program cannot find the module. The compute has Windows Vista.
Old Apr 12, 2009 | 02:25 PM
nate_88's Avatar
Is this the first time you've hooked up your adrenaline to your computer?
Some Vista machines have problems and won't work with the adrenaline. Is it a 64bit or 32bit processor?
Old Apr 12, 2009 | 02:29 PM
rholbus's Avatar
ive tried to hook it up but ive never had the original cable
its a 64 bit
Old Apr 12, 2009 | 02:44 PM
nate_88's Avatar
The 64bit might be your problem. I've talked to Jeremy about this before and he said that the 32bit processors don't have a problem, but a lot if not all of the 64 bits do.
Old Apr 12, 2009 | 02:46 PM
rholbus's Avatar
so i would just have to use a different computer then
Old Apr 12, 2009 | 02:51 PM
nate_88's Avatar
As long as the other one is a 32bit then yes. I've noticed that even though the 32bit Vista platforms say that the drivers for the program were not successfully installed that the program still works. XP is a lot easier to use when you're doing the setup, but if you know what you're doing then the 32bit Vista should work too.
Old Apr 12, 2009 | 02:52 PM
rholbus's Avatar
thanks ill use try my buddies computer he still uses xp
isu elvi
Jun 20, 2008 02:39 PM
ramcummins
18
Jun 7, 2008 12:35 PM
jcmoyer2004
Apr 15, 2008 07:52 AM
dieseldork
13
Mar 23, 2008 05:07 PM
marine4life
Mar 20, 2008 08:33 AM
