98 12v issues help
Old Jan 25, 2008 | 01:01 PM
heykw's Avatar
98 12v issues help
My 98 in my sig, this morning the instrument cluster does not work (no tack no mph nothing) also first gear and OD don’t work I have checked all of the fuses and everything appears good I even replaced the dash instrument fuses Help please.
Old Jan 25, 2008 | 02:20 PM
heykw's Avatar
bump!!!!!!!!!!!!!!!
Old Jan 25, 2008 | 02:31 PM
Diesel- Dummy's Avatar
did you try a new ecm?????
Old Jan 25, 2008 | 03:17 PM
heykw's Avatar
They want 550 at the dealer plus progaming
Old Jan 25, 2008 | 05:02 PM
Danavilla's Avatar
Any CELs? Because the tranny is involved, I'd be suspicious of the PCM but look for loose or damaged wires first. Even a single wire not making good contact can cause multiple problems.
E-mail me and I'll send you the proceedure for instrument cluster diagnosis.
Dan
Old Jan 25, 2008 | 05:22 PM
dieselman2300's Avatar
Crank position sensor?
Check it, make sure its gapped .050" and make sure none of the wires are corroded or worn through.
You will have to take it off the truck to look at it properly. Its only 2 bolts and a plug.
Old Jan 25, 2008 | 09:46 PM
heykw's Avatar
Thanks guys I talked to Jeff Garmon and he is going to send me a PCM to try for free he said he was going to try and over night it to me I will keep you posted
Old Jan 26, 2008 | 07:08 PM
heykw's Avatar
no pcm yet
Old Jan 27, 2008 | 12:46 AM
samasaurus's Avatar
I had the same thing happen to my 98 it was the crank position sensor.
Old Jan 27, 2008 | 12:52 AM
Tate's Avatar
That shouldn't affect speedo, should it?
Old Jan 27, 2008 | 12:58 AM
samasaurus's Avatar
It affects most of the cluster. Is you fuel gage messed up also. although i see you have a 24v and mine is a 12v. but the problems you are having were the same as mine.
Old Jan 27, 2008 | 01:02 AM
samasaurus's Avatar
are you sure yours is a 24V because your signature says you have a fule plate? Tate
Old Jan 27, 2008 | 08:10 AM
Confusing HUH?
Tate P-Pumped his 24 valve truck.
Old Jan 27, 2008 | 03:15 PM
smokeum99ta's Avatar
Better look at the sig again it says 12v not 24v on the lower truck. Maybe he's changed it since your post but i'm just stating the obvious.
Old Jan 27, 2008 | 03:31 PM
heykw's Avatar
yes the fuel gauge is broken and my 98 is a 12v none of the gauges work at all
