91 250m chip upgrade
Old Apr 30, 2006 | 11:42 AM
0629doug's Avatar
Got a 91 looks new only 45k on it looking to upgrade cant find a chip any help
Old Apr 30, 2006 | 11:49 AM
getblown5.9's Avatar
there are no chips for those trucks...all mechanically controlled so you have to modifiy the injector pump to get more power
Old Apr 30, 2006 | 12:18 PM
CTD_Neil's Avatar
Funny, very funny
Old May 1, 2006 | 12:17 AM
Ph4tty's Avatar
Originally Posted by CTD_Neil
Funny, very funny
Be nice, its his first post
The good news is for the price of a chip you can do all sorts of fun stuff with your 12v Doug. I can't tell you what but I do know that guages are usually the first step then let the tweaking begin
How much power are you trying to add? Stick or auto?
Old May 4, 2006 | 07:46 AM
0629doug's Avatar
tweaking a 91 cummins
It has a automatic looking to gain 20+ hp. where do i get gauages tach, trans temp, exhaust temp
Old May 4, 2006 | 07:58 AM
Diesel-Dan's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Check this thread out. I think 20 HP can be had for no $$ at all! I will make a suggestion.....injectors and a turbo housing mod goes along way on your style truck. High Tech Turbo sells a great housing upgrade kit for both the exhaust and compressor side of the H1C turbo. You can find a good injector upgrade to add some fuel to the added air and spool up.
Autometer has a good selection of gauges if you are wanting to find a tach and gauges to match. If you dont care about them matching....there are TONS of gauges to be had....just do some digging and check out some sites that sell them.
BUT MOST OF ALL........WELCOME TO DTR!!!!!
Old May 4, 2006 | 09:23 AM
CTD_Neil's Avatar
Install an HX35 off of a 2nd gen truck, big improvement in power and spool up.
Old May 4, 2006 | 10:13 AM
Teddy Bear's Avatar
Buy a Governor Spring Kit!!!! Its one of the best mods you can do to these trucks. Only around $20 too!
Old May 4, 2006 | 10:25 AM
Lil Dog's Avatar
20Hp is nothing.. With some tweaks to the pump only I had boosted my 93 to over 280HP rear wheel.
Do some reading at DodgeRam.org as well as surf the posts here in the 1st gen area. That should keep you busy.LOL..
Old May 4, 2006 | 11:47 AM
JDGnut's Avatar
Like others have said.. its not too hard to get more HP out of the VE injection pump you have on your truck... do a search in the 1st Gen forum... Most of the guys in there will help you.. less than 15min you can have the HP you are looking for...
Good Luck
Bryan
Edit:... Doug where U from??? Add your location to your USER CP information.. and truck info...
Old May 4, 2006 | 12:27 PM
RowJ's Avatar
Love to see a 91 with only 45,000 miles! How about some pics in your gallery?
And, if within a couple of hrs of Waco and/or Dallas... come to our next club meet!
http://www.riegerweb.com/Nortex_DTR.htm
RJ
Old May 4, 2006 | 12:59 PM
apwatson50's Avatar
Well its really just one little spring, but yes it is a great mod!!
Old May 4, 2006 | 03:25 PM
CTD_Neil's Avatar
Get in touch with STOMP on this board, he has a wicked 1st gen. I've seen it in person.
Old May 4, 2006 | 10:53 PM
Ph4tty's Avatar
Here's a good place for guages: http://www.dieselmanor.com/
Pyro mounted in your exhaust manifold then boost and trans temp should be good
Old May 5, 2006 | 12:31 AM
cumminsdriver635's Avatar
You can get quite a bit of power for cheap. Gauges first.If it were me; I would then turn the pump up with the screw on the side, and install the governor spring, and a 12cm turbo housing. it will be a new truck
Eric
