800-900hp twins
Old Apr 11, 2007 | 04:26 PM
Tiger Rag's Avatar
Originally Posted by Rodram2002
not sure if I want to run #9 or one of the softer smarty settings. I will have the Smarty do my timming.
I'd try some different settings just to see how yours responds if you've got the time.
Old Apr 11, 2007 | 04:35 PM
Rodram2002's Avatar
I think I will only have 2 back to back pulls at the event.
Old Apr 11, 2007 | 05:32 PM
Tiger Rag's Avatar
Well, I'll be interested in hearing your #'s with the Smarty doing your timing. Keep us posted.
Old Apr 11, 2007 | 06:44 PM
99globalwarmer's Avatar
my uncle has a twin turbo race truck and he runs a moded htt71/16 ontop and i believe a custom big brother with a titanium wheel with the trim changed and its a bit larger and he is up in the 900+ range. he said a k31 with a 80mm inducer and some exhaust side wheel mods could turn out 700.but im not to sure.I dynoed 692, and that was with my ddp injectors and the smarty on 7 and the tst comp on 8 i believe.
Old Apr 11, 2007 | 07:25 PM
Rodram2002's Avatar
what about upgrading my S300 to a 64/14? how much would that help? can you put a bigger compressor wheel on an S400?
Old Apr 11, 2007 | 07:54 PM
Mav's Avatar
Mav
Originally Posted by Idaho CTD
The stock S300G would need to be made into something bigger. I dont neccessarily think you'd have to go all the way to a 66mm to reach your goal though. You'll need a much bigger S400 and a wastegate on it to get to the upper end of that range.
Idaho just curious why would a wastegate be needed? Without one youd be able to push more air?? Im confused
Tiger Rag's Avatar
I'd call HTT and talk to Paul and see what he thinks he can do for you. Tell him your goals and I think he can map out a plan for you.
Old Apr 12, 2007 | 12:38 PM
paulb's Avatar
You can put a bigger compressor wheel on a S400, talk to Rip about that. I have a 62/14 on top of the 75mm S400, and made 634hp. Air is not what is limiting my hp, fuel is. 700hp, with enough fuel, and this turbo setup does not seem unreasonable. The next step for me would be to go to a 64/14 on top, and a 80mm S400 on the bottom. After that a 66mm on top of a big brother.
What fueling are you going to use to get to 800-900hp, on a VP truck?
Paul
Old Apr 12, 2007 | 12:54 PM
Rodram2002's Avatar
thanks Paul. thinking way down the line for what I want to do with the truck. either there is that new HOTVP or I will P-pump it and it will be a sled pulling only truck at some point.
Old Apr 12, 2007 | 01:06 PM
signature600's Avatar
If you go P-pump, go one size bigger for chargers than what you would with a VP...at least I would! The p-pump's static timing, and massive fueling will need a bit more air, even with a 24v head!
IMHO,
Chris
Old Apr 12, 2007 | 01:24 PM
Rodram2002's Avatar
what size inducer do most S400 have? a 74mm??
Old Apr 12, 2007 | 02:04 PM
Most are...they make them anywhere from 64 on up over 74/75mm, maybe up over 80!
Chris
Old Apr 12, 2007 | 03:35 PM
80 are pretty rare i had to have one made for me that was that big. its alot slower spooling but it does noticabley move more air that a 75. my k31 is going to be converted to a 80 mm titanium wheel, so i can keep the small side the same quick spool the exhaust side is being converted to a boreless one piece exhaust turbine. its suposed to allow me to spin faster turbo speeds and more boost.
Old Apr 12, 2007 | 05:25 PM
Rodram2002's Avatar
Do you know what kind of air it will flow?
Old Apr 12, 2007 | 05:55 PM
no i dont know but they said alot more proably a couple hundred more cfms im really not to sure.
