6spd swap?
Old Dec 3, 2009 | 09:52 PM
STACKED's Avatar
6spd swap?
What do I need to put a 2001 2wd 6spd in my 98.5 5spd? Will the tail shaft swap out, will the t-case adapter bolt on? Is the clutch and pressure plate and flywheel the same? Any advise would be helpfull
Old Dec 4, 2009 | 11:22 AM
Kamikazekyle05's Avatar
Im interested in this as well
Old Dec 7, 2009 | 01:49 PM
STACKED's Avatar
any body know where to get a 6spd 4x4 tail shaft? also will this 6spd lower my highway RPMs any?
Old Dec 7, 2009 | 02:59 PM
Copenhagenjunkie's Avatar
From quad4x4.com:
First gear and high gear are essentially the same ratios for both the NV4500 & 5600. Reverse gear is lower in the 5600 then most 4500's. The direct gear (1:1 ratio) for the 5600 is 5th, in the 4500 it's 4th. From a drivability standpoint, the difference between the two transmissions is the close ratio spacing of the 5600 doing in five gears what the 4500 does in four. Close shift ratios is a great asset for hauling and towing but a bit of a liability for daily city driving. The 6th or overdrive gear is mounted on the front of the mainshaft instead of the back like the NV4500. Consequently, the NV5600 does not have the problem of the mainshaft nut backing off.
Old Dec 7, 2009 | 04:34 PM
STACKED's Avatar
yeah didnt think it would change much thanks for the reply. know where to get a 4x4 output shaft?
8mpg
Jul 3, 2007 12:57 AM
Smooshy
May 25, 2006 11:10 PM
rambododge
Jan 21, 2006 04:01 AM
westport
Nov 24, 2005 01:43 AM
norsk
Jul 19, 2005 08:26 PM
