5th Guage spot??
5th Guage spot??
Anyone know of a 4 guage pillar for a 94-97?? I've got a three guage now with Pyro/Boost/Boost in it, and another one (air pressure) where the cupholder used to be with my new switches.
I need one more for drive pressure...problem is, where the heck do I put it.
Any suggestions?
Thanks,
Chris
Any suggestions?
Thanks,
Chris
Chris, Only 4 gauge A Pillar I've seen is on Big Blue...home built. (See his gallery)
Had good luck with my Autometer Dash Pod.
Works well for Elec. gauges....was a real PITA for the mechanical Fuel Pressure gauge.
I just use a temp hook up for drive pressure...in my EGT probe hole. Do you need one full time?
RJ
RJ
Check out the one in my gallery. I started with a 3 gauge pod, then added a 'universal gauge pod' from JC Whitney. My gauges are listed in my signature below.
Originally Posted by TxDiesel007
what about that little cubby hole?
My 96 has one right next to the cup holders, IE on the left side... seems like a good spot for a gauge,
Tx
Tx
Thanks,
Chris
Thanks for all the great replies guys!
Looks like I'll be doing 6 gauges now Tranny and rear end temp, too!
Chris
chris, did u get rid of the X-monitor??? I thought I saw one of those on your steering column in your gallery?? a friend of mine was considering the X-monitor is why I was asking, if you got rid of it was it for any particular reason??? you could do a dash mount on the left side beside of the pillar mount, but that might make for a major blindspot running both?? the cubby hole would probably be better if u don't have foglights, Dusty
