5000rpm 12v...
Old Apr 18, 2007 | 12:54 AM
  #31
Muddin_dude06's Avatar
Originally Posted by Teddy Bear
Chris are u sayin that youre turnin 5500?
I'm curious as to this too, what all have you done to your truck to turn those RPM's Chris? I bumped my timing today to 18* and it runs alot better (my timing had slipped down to 3mm of lift) and now I really can't wait to get the new head and cam in and bump up the RPM's some more
Old Apr 18, 2007 | 07:17 AM
  #32
signature600's Avatar
I "can" turn 5500...that's what my pump is governed at. I haven't done anything else to it, not even valve springs, so I don't spin it under power over 4K. The only time Ive taken it past that is when I got the truck running after the pump swap, I just had to hear how it sounded...not too mention I had way too much timing in it and it wouldn't hardly run under 2K, so I had to
It sounded GOOD up there
Hopefully, this winter I can build a new engine, and make it handle those kinds of R's!
Chris
Old Apr 18, 2007 | 09:57 AM
  #33
patdaly's Avatar
Originally Posted by joefarmer
In both videos, the driver had no time to react. I wasn't anticipating a broken trans shaft and Straley had no intentions of breaking either. You saw how much time it took in my video to figure out something was wrong and kill the engine? The instant the trans gave, the datalogger showed a gain of 2200 rpm in less than a second. It was still going up when the crank pickup failed.
brandon.
Oh I agree, thats why I would think some form of Automatic rev limiting would be a godsend.
Just thinking out aloud, if you normally turned say 5500 RPM max on a pull or run, you could put a 5700 chip in and then if an issue happened, it would pull the Normally Open solenoid open shut, removing fuel to the engine in a matter of milliseconds.
I'm sure you might have to use the rev limiter to pull in a relay and slow it down a little, but I couldn't see it taking more than 200 or so Ms to kill the fuel to the P-Pump
03CumminZ4X4
Feb 1, 2008 11:15 PM
Russell_d
Feb 25, 2007 09:12 AM
CTD2001
Feb 3, 2007 01:30 PM
apache
Oct 27, 2004 08:53 AM
