4x4 launch?
Old Apr 28, 2007 | 05:07 PM
Big Dblue's Avatar
4x4 launch?
I went to the track yesturday, and i ran a 17.17 @ 79.07MPH. i was in 4x4 the hole time through the track. I was woundering if that would hurt my truck. So like when i shift from 2nd to 3rd. should i also put it into 2wd? it didnt seem like it hurt my truck but i started to think about it and i dont need it after the launch? Any advice would be great!
Old Apr 28, 2007 | 05:09 PM
BigBlue's Avatar
Nah. You didn't hurt anything. I'd say with an auto go ahead and pull it back in to 2wd but it's a lot easier to do with an auto than a 6spd. Your shifting so fast you probably don't have enough time to pull it before you have to grab the next gear.
Old Apr 28, 2007 | 06:41 PM
blackdiesel's Avatar
Registered
and even if you do kick it into 2x4 it probably wont disengauge from 4x4 until you start to slow down....
Old Apr 28, 2007 | 06:55 PM
Jturs's Avatar
yeah how would you put it back in 2wd while you are hauling a$$. you would think it either wouldnt go back into 2wd or would make a horrible noise or something
Old Apr 28, 2007 | 07:08 PM
01 Dwhite's Avatar
is is bad if you leave it in 4wd the whole time? or will it mess up the front diff.
Old Apr 28, 2007 | 07:24 PM
BigBlue's Avatar
No. It's not bad. Just be sure before you turn to disengage it.
Old Apr 28, 2007 | 09:08 PM
Registered
how much wheel spin do you have in 2x4, with just a ez any way?
Old Apr 28, 2007 | 11:02 PM
Big Dblue's Avatar
well when we went to the track. I only got to race twice. and both times i had it in 4x4. and i have only had the ez for a couple of days and havent really mashed on it from dead stop. but i believe i would spin through 3rd.
Old Apr 28, 2007 | 11:07 PM
Rodram2002's Avatar
i run mine throught the whole 1/4 in 4X4. and i finish at 101mph. I shift into 2wd at the end of my run before I turn off the track
Old Apr 29, 2007 | 09:47 AM
Big Dblue's Avatar
well thats good. Thats what i was doing. I belive that the 4x4 helped alot. all my buddies had 2wd's and they couldnt get no traction at all.
Old Apr 29, 2007 | 08:33 PM
TheBigNasty's Avatar
I highly doubt your truck with just an EZ would spin the tires in 2wd horribly unless you are just utterly trying.
Old Apr 30, 2007 | 12:36 AM
Ph4tty's Avatar
Not bad for a 6 speed. What gear do you start out in?
Old Apr 30, 2007 | 02:09 AM
Rodram2002's Avatar
A 3rd gear launch with the motor sitting at 3800rpm from the start. I need to work on my launch some. I don't smoke at all and I know I can let the clutch out alot faster. My 60' times suck. I'll get it down for the next race I make.
Old Apr 30, 2007 | 07:43 AM
RowJ's Avatar
Originally Posted by Big Dblue
.. I was woundering if that would hurt my truck. So like when i shift from 2nd to 3rd. should i also put it into 2wd? .... Any advice would be great!
Not hurting anything staying in a straight line! I would take it out of 4x4 if you can. May come out of 4x4 between shifts and that could help you times a bit. Also prevents forgetting and trying to turn off the track in 4x4... which I suspect we have all done?
On a auto, it won't go to 2x4 till you back off the throttle, but I still shift it out after third gear because I did forget once.
RJ
Old Apr 30, 2007 | 07:54 AM
cumminsdriver635's Avatar
Mine disengaged 4wd going from 3rd to 4th one time, and it didnt sound the best, so I just leave it in till the end of the run now.
Eric
