4 cranks to start
Old Jul 16, 2007 | 08:34 AM
larabeejj's Avatar
Angry 4 cranks to start
I have an 01 cummins with the lift pump replaced and just replaced the injector pump from midwest fuel injection. Still having the problem of having to crank 4 to 5 times for it to start cold or hot after it sits a 15 min or more. Dodge is telling me that the injector pump I installed is also bad. According to the diagnostics. Anybody have any suggestions.
Thanks
Old Jul 16, 2007 | 08:52 AM
Beast2B's Avatar
there is a check valve after the IP that keeps fuel from draining back to the tank (through the return line) when the truck is not running. sounds like the truck is having to build head pressure from the tank to the IP each time you restart the truck...
also, if I remember correctly, there have been issues with low battery voltage not allowing the engine to crank fast enough to light off. that doesn't seem as likely with your symptoms, but who knows!
Old Jul 16, 2007 | 10:56 AM
larabeejj's Avatar
Where is this check valve located in the return line?
Garlocker
Jun 26, 2014 09:27 PM
stange
Jun 22, 2010 11:08 AM
slubik
Feb 4, 2010 05:28 PM
screaminbanana
Aug 25, 2005 09:30 AM
DRESSER DAVE
Apr 25, 2004 09:17 PM
