View Poll Results: you all with 315s, do they rub?
yes
19
50.00%
no
19
50.00%
Voters: 38. You may not vote on this poll
315s and rubbing
315s and rubbing
I am asking to all of you all with a second gen 4 wheel drive with 315s. Do you alls tires rub at full crank. Please include your suspension setup when you vote whether yes or no.
My 315's on AR wheels rub my air dam, that's it. The 315's on 03 stocker 17's rub the control arms pretty bad before full lock. Stock suspsension.
The 01 Sport gasser has no problems with the ones on the AR wheels, also stock suspension.
my experince is as follows: there are two places "rubbing" can occur. 1) on the control arms due to too wide of a tire and a wheel with too much backspacing. 2) rubbing on the bottom of the fender due to too large of a tire and/or too much offset of a wheel.
with that said i have ran multiple sets of 315's on two sets of wheels. same suspension setup. 2" coil spacer on the front and 2" aal in the rear. first wheels where 16x10's with 4.5" backspacing. these rubbed the bottom of the fender at full lock of steering wheel. that is the only place and time they would rub. second set of wheels which is also my current set is a 16x8 with 5" backspacing. these would not rub at all, anywhere or anytime. with no or minimal lift i believe this is the exact size wheel one needs to run. i know people who have the '01 and '02 factory alloys which i believe are 16x8 with 5.5" backspacing and the 315's would rub the control arms at full lock. so this is my experince and findings. hope it helps you out!
