31.6 MPG @ 5x5 What's not to love ???
Old Mar 23, 2007 | 09:22 AM
  #31
sluggo42's Avatar
Originally Posted by Valv
I believe we were criticizing the fact you are stating your truck does 31.6mpg because you read it on overhead trip computer.
Fill up tank, take your trip, count the miles (be sure your tach/tires are correct), fill up again when you finish, only THEN you'll find out the REAL fuel consumption.
I did originally state that this was just one snapshot from the overhead, or one small slice of the total pie. I can't do a hand calc of a 75 mile snippit. The point was merely to state we have trucks that can get good mileage even with big power. I KNOW that a whole tank won't produce these numbers, it was just a small example, SHEESH!
Never mind, just floor it, burn rubber and burn fuel till theres no tomorrow...
Old Mar 23, 2007 | 09:45 AM
  #32
johnh's Avatar
i was getting around 16 mpg untill i added propane(homade) , now i get around 23, no change in driving habits
Old Mar 23, 2007 | 10:27 AM
  #33
xtoyz17's Avatar
Originally Posted by P.J
I even taught my wife to do it in her car, easy as pie.
My GF could care less, but maybe that's because she's not the one who pays
Old Mar 23, 2007 | 11:23 AM
  #34
SHARPMACHINE's Avatar
Originally Posted by timbeaux38
I found a product that will get you whatever MPG you want
the TCB
Wow, Never been to that site, but some cool people over thare as well!!!!
thanks
Old Mar 23, 2007 | 03:04 PM
  #35
Ph4tty's Avatar
the TCB
Thanks Tim. Now with the TCB I'm up to 1000 hp and 50 mpg
Old Mar 23, 2007 | 03:05 PM
  #36
displacedtexan's Avatar
But then you have to figure in the cost of the propane you are burning. Still cheaper I'm sure!
How did you set up the propane?
The overheads are just so inaccurate. I don't trust them at all on a bombed engine. Because it is basing the calculations on stock fuel delivery. I know a guy with a Superduty on 38's that swears he is getting 35MPG with the Juice, which is close to the 38MPG he got in his 24v 4x4 dually. He doesn't see how the overhead could be off, so he won't check it by hand.
Old Mar 23, 2007 | 05:55 PM
  #37
sluggo42's Avatar
What makes you so sure YOU'RE correct with this statement?
I'm not saying that they are all that accurate, but I believe they process the amount of fuel used vs. miles driven, regardless of bombed or not. If not, how would it know the difference between a stock truck being floored or being driven with an egg inbetween the foot and the skinny pedal.
Old Mar 23, 2007 | 06:00 PM
  #38
xtoyz17's Avatar
I was under the impression that it was a calculation done based off throttle position, rpm, and the fueling map. I might be wrong, though.
Oh, and 12v motors didn't have the option for fuel calculations. Best I can figure is that being all mechanical there's absolutely no simple way of determining fuel consumption.
Old Mar 23, 2007 | 06:16 PM
  #39
~Angry Tractor~'s Avatar
I just took a 550 mile trip (one way). Filled up before I left and again when I got there. I got 20.5 mpg @ 60 mph on the way there. I got 15.7 mpg @ 70 mph on the way back. These were my figures. I had to find a Walmart (it was a Sunday) to get a new tire on the way back though. My truck has 4.10 gears also. I think my old truck would get about 23 mpg @ 75 mph but it had the 3.50 gears and the timing was bumped up on it.
Old Mar 23, 2007 | 06:41 PM
  #40
Tate's Avatar
Originally Posted by 24V-DSL
Your 2wd. weighs 7000 lbs.?
Mine was 6960lbs. with a 1/4 tank with me in it. I weigh about as much as the missing 3/4's.
Old Mar 23, 2007 | 06:48 PM
  #41
99globalwarmer's Avatar
ya man mine says i get 31.3 miles per gallon. the tank drops so fast that, i started making bio diesel and dont care how many miles per gallon i get. i pay like .60 cents per gallon. the truck seems to run better to.
Old Mar 24, 2007 | 12:17 AM
  #42
It is based on the stock fueling map, the box fools the computer, the overhead still goes off the maps, it doesn't actually meter the fuel that is injected.
Old Mar 24, 2007 | 07:54 AM
  #43
Valv's Avatar
How can it do that ? How can it measure the amount of fuel used ?
Old Mar 24, 2007 | 09:34 AM
  #44
P.J's Avatar
P.J
As far as what I've read, it's based on pedal position, messages from the APPS.
Old Mar 24, 2007 | 10:07 AM
  #45
Yeah, not an actual measurement, it's based on the delivery map put in at the factory.
Wettstein
Aug 23, 2010 01:44 AM
Jeff5886
Jul 8, 2009 07:33 AM
sluggo42
Mar 10, 2007 08:33 AM
bigfish5
Sep 19, 2006 12:56 AM
Fat Asp
Sep 8, 2005 08:43 PM
