24V rev limit?
Old Apr 25, 2004 | 02:08 PM
GO 4LO's Avatar
24V rev limit?
Can a 24V ever be built to turn the same revs as a 12V? I've heard of 12V's turning upwards of 5K but never hear anything about the 24V turning that? If not, why not? Thanks.
Chris
Old Apr 25, 2004 | 02:21 PM
SmokinDodge12V's Avatar
Im sure it can be done but not as easy or cheap as it would be on a 12v.
Old Apr 25, 2004 | 03:28 PM
GO 4LO's Avatar
Thanks for the info. So does anyone know what's required to accomplish this, then? Thanks...
Chris
Old Apr 25, 2004 | 03:59 PM
Haulin_in_Dixie's Avatar
You would either have to convert to a P pump or get borsch ot reprogram the VP44. They do it for Cummins, don't know if you coud get them to reprogram one. Maybe a rebuilder can do it.
Old Apr 25, 2004 | 05:06 PM
GO 4LO's Avatar
Do you happen to know the max rpm that Cummins has used out of the VP44? Thanks.
Chris
Old Apr 25, 2004 | 05:32 PM
Chris
Far as I know Dodge 3300, some fire and rv 2700, commercial 2600, commercial 2500.
Old Apr 25, 2004 | 05:36 PM
GO 4LO's Avatar
Great. Thanks for the info, Haulin.
Chris
Old Apr 26, 2004 | 01:45 AM
BigBlue's Avatar
There was one pump out from bosch that would fuel upto I think 6K rpm's, but it was hard to get it there or something like that. Something wasn't working right last time I heard. You would need new valve springs, light weight valves, titanium retainers, new rocker arms (I think), pushrods (I think), cam. It would be expensive, but I'm sure it can be done.
Old Apr 26, 2004 | 04:26 PM
GO 4LO's Avatar
Thanks, guys! I'll see if I can dig up some more info on that pump...
Chris
Old Apr 26, 2004 | 04:37 PM
Mcmopar's Avatar
WHY , If you want to turn a lot of RPM's build a gasser!
Old Apr 26, 2004 | 05:01 PM
GO 4LO's Avatar
Same reason people race diesels instead of big blown gas motors. FUN . Plus, nobody is going to break the 1,000 hp barrier at stock RPM's .
Chris
Old Apr 27, 2004 | 01:50 AM
BigBlue's Avatar
Originally posted by Mcmopar
WHY
Why not?
Old Apr 27, 2004 | 07:59 AM
Mcmopar's Avatar
Now is that 6000 rpm diesel almost like a "nearly" stock 9.98 second corvette??
Old Apr 27, 2004 | 10:57 AM
GO 4LO's Avatar
Not sure what you mean? Unless you're saying the truck is as modified as that Vette at that point, in which case, I definitely agree!!
Chris
Old Apr 27, 2004 | 11:05 AM
Mcmopar's Avatar
That's exactly right, lots "O" money!!
coreydr2003
Feb 11, 2008 07:21 PM
jjj_85
Nov 19, 2006 06:07 PM
GCSS
May 18, 2005 11:28 AM
Ttexas25
Aug 28, 2004 10:15 AM
jt
Mar 17, 2003 08:44 PM
