23 psi on 24V but no codes or de-fueling?
Old Jun 27, 2004 | 08:07 PM
243's Avatar
243
I installed a Sport Comp 35 psi gauge this afternoon and took the truck for a spin. It will make 23 psi in 4th if I hold it to the floor at the upper rpm range.
A buddy said the gauge is wrong or I have a boost fooler because it should de-fuel like my 99. I don't remember the specifics when we first installed the 275's on my 99 but he remembers it laying down quick after 21 psi +/- and setting a code...he's about 10 years younger which accounts for my lack of memory.
My 01 just seems to pull right up to max boost with no apparent change in performance.
Cruising at 55 in 4'th it's about 3-4 psi.
I checked the MAP sensor and the factory plug is in place with nothing inline with it and I checked for codes with key-on key-off method but nothing registers.
Bad gauge, confused truck???
Old Jun 27, 2004 | 08:46 PM
phox_mulder's Avatar
That very well could be right.
Wastegate should be set for around 20psi.
That could be 19, that could be 23.
phox
Old Jun 27, 2004 | 09:21 PM
243's Avatar
243
What about an over boost code?
Old Jun 27, 2004 | 10:09 PM
Maybe overboost is set at 25-30?
phox
Old Jun 28, 2004 | 12:41 AM
BigBlue's Avatar
Mine used to push 23 or 24 when it was dead stock. No defuel or code. It's settled down to 19-20 though. The tolerances are very slack at the factory. Overboost is probably at 25 psi.
38 Cigarette
16
Aug 28, 2015 11:27 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
