215 injectors???
Old Feb 18, 2007 | 03:02 PM
smkn97s's Avatar
Question 215 injectors???
I have the stock injectors out of my 97 5speed 215hp truck, My friend has an 94 auto 160hp truck would my stock injectors help him? If so how much hp should they give him?
Old Feb 18, 2007 | 03:05 PM
NMCTD's Avatar
yeah they should help, probably about 40hp or so
Old Feb 18, 2007 | 03:24 PM
smkn97s's Avatar
His truck is really sluggish it has a zero plate slid full foward,boost elbow,afe intake, 4" exhaust and timed at 15.5* maybe im just used my truck having bigger injectors but his truck really needs some help. It dosnt smoke much at all is this normal for the 160 pumps??
Old Feb 18, 2007 | 04:05 PM
NMCTD's Avatar
They are kinda low in power, and the injectors will help some. Might want to also replace the overflow valve, clean the fuel strainer, and replace the rubber fuel lines that go from the back of the engine down to the frame. Also have him check his throttle cable, those older ones have a tendancy to stretch and not allow full throttle. Push the pedal to the floor and have him grab the throttle cam on the pump and see if it is getting full travel.
Another thing that will make a huge difference is if he has an auto tranny and its stock, I see you have an ATS and that is one of the biggest improvements you can make on an auto truck. The stock auto sucks REALLY bad so a converter and vb upgrade would help alot more than any fuel improvements at this point.
Hope this helps....Josh
Old Feb 18, 2007 | 04:19 PM
NMCTD's Avatar
One last thing make sure he has guages (boost and pyrometer). With a zero plate he should be pushing atleast 35psi or better, if he's not then he may have a boost leak. Also zero plate with a stock turbo can get kinda toasty and I'd hate to see him burn it up.
Old Feb 18, 2007 | 04:58 PM
smkn97s's Avatar
Hes buying my ats converter but my valve body wont work on his truck. Im going with a full billet dtt with 48re valve body and drum from TIM in Va.Thanks for all of the help NMCTD we'll check that stuff out. Oh just to let yall know i have my ats valve body for sale.
Sonny
Feb 21, 2004 04:46 PM
berner
Feb 6, 2004 04:24 PM
berner
Oct 23, 2003 06:45 AM
rharveysr
Jan 25, 2003 05:36 PM
