215 injectors
Old Jan 24, 2003 | 09:03 AM
rharveysr's Avatar
215 injectors
What is the most hp that can be produced with the stock 215's??? I currently run the #11 plate from TST but there are some things in the works that I could be replacing it with bigger plate. And I was wondering what the limits are on the 215's..<br><br> Rick
Old Jan 24, 2003 | 10:20 AM
bulthisl's Avatar
Re:215 injectors
Never dynoed ( Yet )<br>But I'm runnin 215's and a # 5 plate slid all the way forward.<br>It runs great.<br>I'm looking into 370's soon but I have a couple other things to do first.<br><br><br> : Eddie : 8)
Old Jan 24, 2003 | 10:28 AM
rharveysr's Avatar
Re:215 injectors
Eddie,<br>What kind of EGT's are you running with this setup??? Are you still running the stock HX35/12 turbo???<br><br>Rick
Old Jan 24, 2003 | 11:04 AM
Don M's Avatar
DTR Advertiser
Re:215 injectors
I made 348hp with the 215's on a hot summer day and a number 11 plate, and a stock turbo a couple of years ago. It had more in it.<br>Prolly 400 with a 10 plate and HX40 <br><br>Don~
Old Jan 24, 2003 | 07:01 PM
turbo thom's Avatar
Re:215 injectors
Don:
How was the smoke with the 35 and # 11 plate?
I think I'm ready to pull the 370's out of mine and go to a # 11 plate. I do have the 14 housing, though.
..Preston..
Old Jan 25, 2003 | 07:15 AM
bulthisl's Avatar
Re:215 injectors
Rick
Yes I'm still running my stock turbo.
I can warm it up if I try but it is very managable.
I use my truck to haul farm equip. on a regular basis.
I gross 25-30,000 lbs quiet often.
My Pyro is post turbo and on a big hill I can make it climb, but I try not to go past 1150 deg. ( POST ).
I can back out and still pull the hill and prob still in front of most.
I am going to try a 14 - or 16 housing before I go to the 370,s.
Check my sig and you will see all that I am runnin.
The think that has helped my EGT's at this point is my Scotty II.
If you have any questions feel free to pm. me or I usually check in here on the forums.
: Eddie : 8)
Old Jan 25, 2003 | 05:36 PM
GSchlegel's Avatar
Re:215 injectors
You can see my sig., I dynoed 375hp and 798 ft. lbs. torque. That was all the dyno would put on her, boost only went to 36# and EGT went to 1150*. She will peek 39# and over 1500* (pre-turbo).<br>Gene
southernsmoker
Feb 24, 2004 03:13 PM
Sonny
Feb 21, 2004 04:46 PM
berner
Feb 6, 2004 04:24 PM
berner
Oct 23, 2003 06:45 AM
