2001 H.O. dead pedal. Truck only idles.
Old Jan 4, 2011 | 12:58 AM
1generationkid's Avatar
Just bought a 2001 H.O. stock truck. I was driving the truck back to michigan from colorado and while I was cruising down the interstate the engine light came on and the truck lost all power. It will only idle. It has 15 psi on the gauge and good oil pressure. My first thought was the lift pump or injection pump failure. I turned the truck off and started it back up and the light was still on but the truck had full power. Does anyone have any ideas what would cause this. I am stuck in omaha nebraska right now until i fix it. Does anyone know of any good shops that could look or fix this in omaha. Any help is appreciated.
Thanks
Old Jan 4, 2011 | 01:12 AM
Just checked the code and it said P1693. P1693 Generic fault indicating a fault in the bus or PCM/ECM interface. Would the truck be ok to keep driving this way. would it make it from omaha to michigan.
Old Jan 4, 2011 | 01:26 AM
Tate's Avatar
My bet is a faulty APPS.
Old Jan 4, 2011 | 06:03 AM
johnh's Avatar
yep! it probably runs ok with cruise control
Old Jan 4, 2011 | 08:13 AM
high bid's Avatar
My crank position sensor caused my engine to die a couple of times going down the hwy. Replaced and no issues since. Definately check for codes.
Old Jan 4, 2011 | 11:29 PM
nickg's Avatar
heres a link to read to help diagnoise
http://www.bluechipdiesel.com/vp44diagnostichelp.html
1generationkid
Jan 5, 2011 10:29 PM
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
seagravedriver
May 30, 2004 12:50 PM
