12V Turbo help
12V Turbo help
Well i finally blew the factory turbo in the fummins. So ive been looking at turbos at work. I work for a John Deere Dealership.
Here is measurements off of one tell me what u think...
the fummins has a #8 plate and 75hp DDP injectors.
Its a Garett turbo.
Compressor
6 Blades
Ind: 51.92 mm
Exd: 74.89 mm
Outlet 2.5"
Intake Side 4"
Turbiner Wheel
4" V-Band
Ind: 74.89 mm
Exd: 63.61 mm
JD# RE31258
Its a Garett turbo.
Compressor
6 Blades
Ind: 51.92 mm
Exd: 74.89 mm
Outlet 2.5"
Intake Side 4"
Turbiner Wheel
4" V-Band
Ind: 74.89 mm
Exd: 63.61 mm
JD# RE31258
From the part number I found that its probably off a 7.6L (466 cubic inch) John Deere used in maybe a 55 or 60 series tractor.
What size flange in on the turbine housing? T4 or T3? Unless you have a special manifold or an adapter the cummins needs a T3 flange.
03CumminZ4X4
Feb 1, 2008 11:15 PM
Russell_d
Feb 25, 2007 09:12 AM
CTD2001
Feb 3, 2007 01:30 PM
