100K valve adj maint and F1 injectors
Old Aug 31, 2009 | 06:43 PM
dodgerdog's Avatar
I'm about to pull my truck in for the 100K valve adjust maintenance, and have decided to change out the stock fuel injectors - looking at F1 injectors. I'll be towing a 5er soon, and am wondering what injector set from F1 would be the best bang for the buck - thanks, DD
Old Aug 31, 2009 | 10:43 PM
rebal's Avatar
Mach 1.6 if your pullin a heavy trailer and want good MPGs you will love the 1.6s and for the most part there safe enough that your not freakin out at the EGTs you will need a tuner to get the most out of them If you have an AUTO it will grone unless built to take the power manual will be fine
Old Sep 1, 2009 | 07:46 AM
Joe Diesel's Avatar
I got Mach 1.6 in mine and they run great ... mind you I have an Edge Comp & Smarty stack too
Old Sep 1, 2009 | 07:54 AM
mishkaya's Avatar
I think the Mach 1.6's are probably the best all around injector that F1 makes. Have a set in the '02 and couldn't be happier with them. Awesome injector for stockish trucks.
Old Sep 1, 2009 | 08:14 AM
Homestead's Avatar
If your going to go F1 Mach 1.6, you might as well drop in a set of 1.75's.
I went this route with a Smarty and love it. EGT's are more than driveable even when towing ( I tow upwards of 12,000 lbs).
Don't be surprised if you find that your 100K valve adjustment isn't needed. My truck as well as a fair number of friends trucks still haven't needed the valves adjusted, they are still within spec.
Jeff
Old Sep 1, 2009 | 09:55 AM
PaulDaisy's Avatar
Depends on where you live.
If you live at lower elevations, 1.6 is best. If you live at high elevations, 1.6 or 1 will work best. I went with 1.6 and it is easy to get to 1,200F EGT towing uphill. If I would have to do it again it would be a toss-up.
Just my personal opinion.
Old Sep 2, 2009 | 01:08 AM
Mike Holmen's Avatar
The Guru
A six speed truck, you could go with 2.0's, running a HX-35. The 1.6 sticks are good for auto/ and fiver's. The HO pump just doesn't have the high rpm fuel kick like a So pump does.
Old Sep 14, 2009 | 07:22 AM
dzlfarmboy's Avatar
My good friend has had a set of 1.6's for 150,000 miles and alot of towing with them in his 01 6spd. They are a great injector for daily driving and towing. They can creap up to 1200* with a Smarty or Edge EZ together but are very managable. Usually would have to pull big hills in 5th gear to keep under 1200* with the chip on too. And they get excellent milage too.
rampac
Jan 29, 2010 11:45 PM
Steve V.
Mar 16, 2008 06:44 AM
vtailflyer
Jan 14, 2004 10:20 AM
Suburbanite
Dec 16, 2003 07:42 PM
CTDinMT
21
Nov 3, 2003 09:20 PM
