#100 plate?
Old May 4, 2004 | 01:59 PM
gunracer1's Avatar
#100 plate?
seems joe made a new plate, the # 100 #10 on the bottm, #0 on the upper. i made this plate for my truck a while ago. and i don't mind if anyone wants to copy mine, even thought i did the research and development to make sure it worked well. this just makes me laugh a bit. as much as people get worked up on copying plate profiles. i grind all my plates now, and on my buddies. why people still try to cry foul is beyond me.
Old May 4, 2004 | 07:04 PM
infidel's Avatar
I don't think anyone is crying foul unless the guy grinding them is also selling them especially if they're also copying TST's profile and number system.
Old May 4, 2004 | 08:53 PM
boughtadodge's Avatar
Hey Mike how well does the plate work?
Old May 5, 2004 | 01:07 AM
dsljunkie's Avatar
Yeah, How well does it work? and how does it compare to just a plain ol' #10?
Scott
Old May 5, 2004 | 09:08 AM
gunracer1's Avatar
it is just like a #10 on the bottom, quit drivable. and fuels like a pig when the boost hits 15 or so. it will lay down a cloud when i want it to. i guess it added 40 or so hp on the top. i did not cut it to full 0 depth, i just shoved it forward 40k or so. i am real happy with it, boost went up 4 psi and egts roll up pretty quick. i need more air to take advantage of the extra fuel. i could slide it forward somemore and i think i could still pick up some hp but the egts would really be scary with the hx35.
Old May 5, 2004 | 11:25 PM
dsljunkie's Avatar
Sounds like a winner . I may have to get a profile of that plate from ya. I just happen to have a stock plate layin around that could use some work . Ill be up in Ft. Worth on Saturday for a Longhorn sale at Will Rogers and to pick up some parts that Joe Bob has for me, you think you could give Joe a copy to give to me or somethin?
Scott
Old May 6, 2004 | 09:50 AM
gunracer1's Avatar
hey clean out your pm's
Old May 6, 2004 | 12:08 PM
atc250r's Avatar
I'd really like a profile of that plate too. My #11 isn't really what I wanted so I'd be glad to carve my stocker up.
John
Old May 6, 2004 | 09:48 PM
dsljunkie's Avatar
done.
Old May 7, 2004 | 04:24 PM
Rockyhud's Avatar
gunracer1,
I'd really appreciate it if you could PM me with a profile of your #100 too. I'm about to embark on the BOMB trail and this plate sounds like quite the item.
Thanks,
Steve
Old May 7, 2004 | 04:27 PM
gunracer1's Avatar
this plate will blow your stock clutch in a million pieces and run your egts way hot.
Old May 7, 2004 | 05:23 PM
BigBlue's Avatar
Schweeeeeet.
Old May 8, 2004 | 07:25 PM
cummins24's Avatar
Will the Con FE hold it. I just had one put in my truck last week after spinning the hub out of my Con O. My father in law has a machine shop and I was going to get him to grind me a #0, however will that #100 plate be a better daily driver plate, and if so I would like a copy of the specs of it. Thanks
Old May 8, 2004 | 10:58 PM
guyssets's Avatar
From: Different City each Week of the Year, Currently: Newtown Ct
Question
sorry about this, but i am confused...
what is this 'plate' ?
and where does it go, so on & so fourth...
thanks, and sorry to be backtracking
Old May 8, 2004 | 11:03 PM
Forrest's Avatar
Muted User
http://www.turbodieselregister.com/f...hreadid=101016
