01 upgrades
Old Mar 16, 2007 | 04:24 PM
DMAN99's Avatar
Talking 01 upgrades
just purchased an 01 3500 high output dually six speed. Just wanting to know what the best upgrades for me 400-500 HP and some of the downfalls of the truck? Thanks
Old Mar 16, 2007 | 04:58 PM
smokindog's Avatar
First check to see if you have a 53 block. If you do and push towards the 500hp mark it could very well be a major headache for you.
Other than that to get to the 500hp mark you should....
1) Start with gauges (EGT, Boost, Fuel Pressure)
2) 4" Exhaust and a better intake than stock
3) FASS
4) Clutch
5) 150hp+ Injectors
6) TST or Edge box
7) Bigger charger (62, 64, 66, or twins)
Now for the ballpark costs.....
1) Around $400
2) At most $1000
3) Around $500
4) Around $1300
5) No more than $900
6) About $600
7) Near $1600
Total = $6300
Not too bad considering I have almost $6K in my transmission alone!
You may want to pick up a BD short shift kit too to lessen the throw of that 6 speed. It is very noticeable when grabbing gears in a hurry. Used ones can be had for under $200, that is if someone is actually willing to give one up.
Old Mar 16, 2007 | 07:13 PM
blackdiesel's Avatar
Registered
I had my 02 3500 up to 529 hp had about 6-7k in getting it there, after rebuilding the tranny (nv5600) for the 2nd time (700 the first time and 2200 the last). and I didn't even blow my head gasket. I would have if I would have run it that way any longer though. that would have been another 2k to fix. I've now put my truck back close to stock (just a smarty) and bought me a 78 t/a and make it go fast. I'm going to use my truck to work with and play with something cheaper to break. but that's just me. go for it, just be prepared to spend some cash and suffer some down time. You could stay around 350-400 hp and not have as many problems JMO
Old Mar 16, 2007 | 10:42 PM
BCSCUMMINS's Avatar
Mine put 480hp I got around $3,200 in it. good luck
Old Mar 17, 2007 | 04:18 PM
DMAN99's Avatar
how do I tell wether or not I have a 53 block?
Old Mar 17, 2007 | 04:37 PM
dodgeguy71's Avatar
It will have a number cast in the side of the block. It will be on the driver side of the engine, just above the oil pan. I believe it is maybe kinda 6-10 inches from the front of the motor. If it is a 53 you'll see it. If you don't see a 53 then it is not. I could not find a number on mine and then looked at a guys truck that had a 53.
You could get edge nozzles and have a pump shop put the nozzles on and pop test them to make sure they have a good spray pattern for a lot less than $900. I priced out 125hp nozzles for $291 and not to sure on the cost to put on the new nozzles and get them pop tested. I think one place may have told me $25 for each injector?? I was also told you can put the nozzles on yourself then have them pop tested.
Old Mar 17, 2007 | 06:22 PM
DMAN99's Avatar
why is the 53 blocks undesireable?
Old Mar 17, 2007 | 06:41 PM
24vCTD's Avatar
Bad casting; prone to cracking
Old Mar 18, 2007 | 06:51 PM
DMAN99's Avatar
how much power can you get out of one safely?
Old Mar 18, 2007 | 06:55 PM
P.J's Avatar
P.J
Originally Posted by saab9k
need to check mine to see if it is 53 block.
bought it for $ 6.
allmoast got it going, will post pic. soon
$6.00?
That sounds like the deal of the century, or are you missing some zeros?
Old Mar 22, 2007 | 02:52 PM
DMAN99's Avatar
just wondering if anybody knew
wooff
Mar 25, 2003 05:06 PM
j
51
Nov 19, 2002 08:34 AM
crossy
Nov 14, 2002 11:26 AM
bkay
13
Oct 28, 2002 04:44 PM
