Windows XP
Old Sep 11, 2004 | 05:13 PM
midwestdually's Avatar
Windows XP
can someone help me out....i am looking to get te task bar back on the bottom of the computer. i hit something and now the task bars(that show the programs you are running is not there) and everytime i minimize something i cant find it again
any help would be appreciated...i know it is dumb but i am really burned out with things..thanks again
Old Sep 11, 2004 | 05:32 PM
djp9747's Avatar
Muted User
Most likely you minimized it. Here's what you need to do. I'm assuming your taskbar was on the bottom of the screen.
1. Drag your mouse cursor to the very bottom of the screen
2. It should change from an arrow cursor to one that has two arrows pointing up and down.
3. Click you left mouse button and hold it down
4. Move the mouse cursor up about and inch, and your task bar should pop back up.
Old Sep 11, 2004 | 05:47 PM
i have like a 1/2" area of black around my screen...cant seem to find it...i do know what you are talking about tho...anyother ideas?
Old Sep 11, 2004 | 07:38 PM
amartinson's Avatar
Got this off my XP help. It is how to HIDE the taskbar. Hopefully, you can work backwards and redisplay yours.
To hide the taskbar
Right-click the Start button, and then click Properties.
On the Taskbar tab, select the Auto-hide the taskbar check box.
Notes
To redisplay the taskbar, point to the area of your screen where the taskbar is located.
You can temporarily hide the taskbar by dragging the top edge down. To redisplay the taskbar, drag the visible edge upward.
Old Sep 11, 2004 | 10:38 PM
bulabula's Avatar
Once you figure out how to unhide it, you could adjust the screen display and stretch it out get rid of that half inch of black surrounding it.
Old Sep 12, 2004 | 07:28 AM
hoot's Avatar
Sometimes there's a line accross the bottom of the screen. Drag it up to pull up the bar. Only works if it's unlocked though. Once you get it back you can right click on it and see some options. You can drag the task bar around the screen... to the side, or up top, make it one icon or two icons thick...
Old Sep 12, 2004 | 09:14 AM
Hannibal's Avatar
Go to your "my computer" folder on your desktop, then click on control panel, then click on "start menu and task bar, then you can play around with check boxes regarding your task bar. This should fix you up.
Rednecktastic
Nov 15, 2010 09:29 PM
04ctd
Dec 23, 2006 08:23 PM
markster
Oct 7, 2006 02:20 PM
drecu
Dec 12, 2002 07:06 AM
drecu
Nov 9, 2002 11:38 AM
