transfer case question/
Old Aug 3, 2009 | 01:46 PM
cowboyup007's Avatar
i got another drive train given to me, it's a 3/4 tonne drive train, its 4x4, the t-case is little different then mine, it has 2 hi, 4 hi, neutral, 4 lo, 4 lo lo, is this a good t-case? I believe its could be military drive train but cant be certain. thanks
Old Aug 3, 2009 | 01:50 PM
RowJ's Avatar
Definately not a Dodge 2nd Gen or 3rd Gen.
Sounds military!
RJ
Old Aug 3, 2009 | 02:02 PM
yea, its from the eighties but axles are the same as what i got i believe. Everything looks the same, would this "military" rear ends and t-case be any good if i wanted to pull the truck, are they alot stronger then factory stuff?? I got a 1991 cummins, 4x4 reg cab.
Old Aug 3, 2009 | 03:28 PM
Billut's Avatar
what transmission (if any) is it bolted to?
Old Aug 3, 2009 | 03:46 PM
93-12Smoke's Avatar
Any marking on the xfer case? Sometimes the military stuff is stronger but lets remember they usually pick the cheapest bidder.
Old Aug 4, 2009 | 01:31 AM
cbtumedic's Avatar
Might be a np203 with a 2wd kit installed, they had a 4 low lock detent. I have seen it abreviated as 4lo lo once or twice. It was a pretty prevalent t-case in the '70's and '80's. Is it a pretty large cast iron t-case that's chain driven?
wyododge
Aug 18, 2011 07:48 AM
tjohnson
May 27, 2005 01:06 AM
FRANKV569
Dec 31, 2004 01:05 PM
Pike
Oct 3, 2004 09:30 AM
