Tractor help
Tractor help
Is anyone here a Massey guru? I got a mf 165 with strange predicament. The draft control picks up and lowers implements no problem, but the lift lever lever (inboard from the draft lever) won't budge. I'm hesitant to pull it all apart bc the draft control works just fine, but I'm puzzled as to why the lift control won't move. Ideas?
This may be a stupid question, but don't some of those tractors have a sliding lock or limiting feature on the handle? If so, could the lock have moved and you did not notice it?
Is there a shut off valve or limiting valve for it? I had a roll pin on my lift control lever work out just enough to lock the control in place. Tapped it back in and good to go.
dieselfan
Dec 3, 2006 10:23 AM
