Tire/Wheels size
Old Jun 24, 2003 | 05:20 PM
pvmorano's Avatar
Tire/Wheels size
On a stock (no lift) 98 2500 Quad Cab 4x4, what is max tire size it can take. Also, does anyone know the max tire size the std 6.5x16 wheels can take?
Old Jun 24, 2003 | 07:17 PM
SjLingenfelter's Avatar
Re:Tire/Wheels size
I would put a 305/70/16 on there. That basicly equals a 33x12.50R16.
Old Jun 25, 2003 | 12:27 AM
Suburbanite's Avatar
Muted User
Re:Tire/Wheels size
Alot of places won't mount the 305's (~12&quot; wide) on the 6.5&quot; wide rims. If you want approx the same height you can run 255/85's which are only 10mm (~0.4&quot wider than 245's AND can be safely mounted on the 6.5&quot; rims. Only drawback to the 255's is their 'taller' sidewall relative to width. Has about the same sidewall height at ~8.5&quot; as the 305's but on a narrower tire. Not an issue as far as I'm concerned but you &amp; others may feel differently. All widths are nominal &amp; cross-sectional NOT actual contact patch which is narrower.<br><br>Good luck
Old Jun 25, 2003 | 01:25 AM
Re:Tire/Wheels size
Oh i didnt know that you were mounting them on 6.5 rim.
Old Jun 25, 2003 | 07:20 AM
pvmorano's Avatar
Re:Tire/Wheels size
Am still debating whether to go to a new wheel so as to get a larger tire, or stay with stock wheel and go with smaller tire. I was told you can mount 285x75 on stock wheel??? Will the 305's clear ok with stock suspension?
Old Jun 25, 2003 | 02:25 PM
doodah's Avatar
Re:Tire/Wheels size
yes they will, I have them on my stock rims right now.-{but not for long!!} ;D ;D ;D
Old Jun 25, 2003 | 05:24 PM
jfpointer's Avatar
Re:Tire/Wheels size
[quote author=pvmorano link=board=10;threadid=16299;start=0#153133 date=1056543650]<br>Am still debating whether to go to a new wheel so as to get a larger tire, or stay with stock wheel and go with smaller tire. I was told you can mount 285x75 on stock wheel??? Will the 305's clear ok with stock suspension?<br>[/quote]<br><br>Stock wheels vary in width, I think, on certain years. Someone mentioned a 6.5&quot;--that's the earlier truck. Later trucks have 7&quot; wide wheels. Sorry, but I'm not sure where the split is year-wise. You might be able to find that info on http://www.dodgeram.org. He's got quite a bit of stuff on there. As far as recommended rim widths for various tires, the best source is the tire manufacturer. I know Dunlop posts that on their website. I had a 98 1500 with the 7&quot; rims on it that had 285/75-16s on it when I bought it, so it should work ok.
oldwhite12v
Mar 25, 2011 04:28 PM
CarBizIndio
27
Nov 25, 2007 06:27 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
ValkSmile
Jan 23, 2007 11:42 AM
Firstgenner
Oct 18, 2006 06:09 PM
