Think Diesel's have traction issues... (pics)
Old May 30, 2006 | 05:53 PM
John Rodriguez's Avatar
Tire Hater
My new little project car. 91 240sx hatch with sr20det motor, pushing 250whp weighing in at 2,400lb with driver. That's me smoking the tires (i spooled the rear end) past the 1\8th mile.
Old May 30, 2006 | 08:35 PM
nickleinonen's Avatar
i wouldn't mind having a little tuner like that... little engine, lots of boost and some spray makes for fun combo
Old May 30, 2006 | 09:30 PM
12PACK's Avatar
You really have something against tires, don't you.
Old May 31, 2006 | 03:26 AM
Tire Hater
**** right. Right now there is NOTHING inside the car except the pedals, and steering wheel. I've pulled all the sound deadening material, fiberglass\rubber matt on the firewall, and LOTS of extra wires that aren't neccessary. All the a\c components including heater core were removed. I hope she'll weigh in a bit under 2,300 w\o driver. Lots of extra brackets (including 2 15lb brackets on the engine used for a\c and powersteering) were removed, lots of stuff pulled out
The rear end is out waiting to go to the shop tommorow so I can weld 'er up (just like my last 240, spooled rear ends are fun) and get 'er back in to the car tommorow. I redid the i\c piping and brackets today, 3" all the way through. From previous experience on other 240's, spooling the rear end and pulling carpet \ sound deadening means a whole 1 second drop in the 1\4. If that holds true for this beast, she'll be running a low 13 on 7psi of boost (stock is 11!). So there will be alot of fun on Sunday, as my manual boost controller came in today. I'll make a baseline run with the weight loss \ spooled rear end, then crank the boost to 11psi and have some fun. I figure mid 12's are very atainable Sunday night. I'll post vids \ pictures of the build up (or down) tommorow, as well as any dynosheets on 7psi and 11-12psi.
J Lent
Competition / Pulls / OffRoad
16
Oct 19, 2008 08:13 PM
Baja
15
Oct 3, 2008 12:29 PM
agalaczy
Sep 4, 2008 06:59 PM
LUKE-MM-PULLER
Jul 13, 2007 10:46 PM
Bobcat698
21
Jun 15, 2006 08:31 PM
