Super singles - why?
Old Sep 30, 2006 | 01:32 AM
12valve@heart's Avatar
Lately I've noticed quite a few more trucks and trailers running super singles instead of duals. What's the benefit or reason to choose one over the other?
Old Sep 30, 2006 | 05:52 AM
That's an interesting answer to a question about tires, Mike. Got a little case of turbo obssesion, I see.
Super singles are used where the empty weight of the truck/trailer is very important. You'll see them a lot on fuel tankers. Less weight in the rig = more gallons of gas going down the road. It's the same for other cargoes that are heavy but not too bulky. You won't see them on a Frito-Lay truck. They also help economy, but not a lot of fleets run them for that reason exclusively because the savings in fuel don't offset the tire cost. Duals are much cheaper to buy, and if one of a pair blows the truck can be limped to a safe place for service with no damage to the rim.
Old Sep 30, 2006 | 05:56 AM
Marine's Avatar
Veteran: Marine Corp
Good catch.
You can tell I definitely have turbos on the mind.
I got all excited by the 'Super Singles'
Too little sleep will do that to a guy.
I'll fix it. LOL
Old Sep 30, 2006 | 09:57 PM
Crimedog's Avatar
I was reading a tire study a couple of weeks ago and I remember it saying that super singles are becoming more popular because if the diameter of your duals is off just a little bit you end up causing serious wear that just compounds until a tire fails. Example: If the inside tire is a smaller diameter, it is going to "drag" as the outside rolls normally which causes major heat buildup until it fails.
Old Oct 1, 2006 | 06:24 AM
1st gen Hobie's Avatar
Where did the info on where to get these go?
Old Oct 1, 2006 | 09:43 AM
There never was any info on where to get them.
Old Oct 1, 2006 | 12:03 PM
prattman's Avatar
www.chromewheel.com I e-mailed them about three weeks ago for a quote on their 8 lug directional float wheels. Haven't hear from them yet. I guess I'll have to call. Also American Force Wheels have them. http://www.americanforcewheels.com/super.html Any Alcoa heavy truck dealer should be able to order the wheels, then you would have to purchase the 8 lug to 10 lug adapters.
Old Oct 1, 2006 | 03:52 PM
Red3quarter's Avatar
I worked for a fleet that used the 445/50/22.5 Michelin X-ONE XDA's on some of the drive axles and trailer axle on their semis. They went to the for the mileage, but since i had to change them I actually prefered them over the normal 11r22.5's they were running. They don't look it but they actually were easier to mount and dismount on to a wheel, they seemed to "give" a little. Plus when a truck came in for drive tires to be replaced you only did four instead of eight.
Stamey
Big Rigs
33
Nov 13, 2009 08:25 PM
genros
Dec 18, 2006 09:02 PM
Jus Cruisin
Nov 20, 2006 06:22 AM
Syndicate
Jul 7, 2006 11:58 AM
mavrick211
Dec 26, 2005 08:48 PM
