Stereo ideas... for the boat
Old Feb 13, 2005 | 04:24 PM
midwestdually's Avatar
i was wondering if you guys can tell me if this setup is condusive for my needs and make sure i have all my ducks in a row...here goes...
currently:
sony head unit 65x4...
4 sony 100watt marine 6.25's
wanting:
4 6.25 polk audio momo tower speakers/cans 125w continous...250w peak
1 kicker kx650.4 170w x 4 @2 ohms
is it my understanding that with that amp i can run all the speakers in my boat at 2 ohms achieved by running my left momo's +,+ and -,- to 2 channels on the amp and then run the same configuration with my existing stock speakers ...i will be at 170watts per individual speaker correct or only 85watts?
Old Feb 14, 2005 | 05:23 PM
no one has a response?
Old Feb 14, 2005 | 05:34 PM
BigBlue's Avatar
Sounds good to me. I'd go to the manufacturer's website for the wiring diagram.
Old Feb 14, 2005 | 09:25 PM
SjLingenfelter's Avatar
Whats the ohms on th speakers?
Old Feb 14, 2005 | 11:37 PM
4 but 2 stable
Old Feb 15, 2005 | 08:28 AM
Kyle Graham's Avatar
That should be right 170x4
Old Feb 15, 2005 | 08:30 AM
If im reading this right you will be at a 4 ohm stable since the speakers are wired in ++ -- so there for you SHOULD be running about 85 watts per speaker cause you are running 4 speakers in to 2 speaker ports on the amp which will make it 4 ohms maybe less but no less then 3 running about 85watts.If you lower the ohms to 2stable you will run 170watts. I know its confusing. Sorry if you dont understand...Your best bet would be to run each speaker off of each port on the amp that way you will be at a 4 ohm stable with 170per speaker for sure.
Justin26
Oct 29, 2007 05:58 PM
TexasCTD
36
Dec 17, 2006 09:28 AM
Fisherguy
0
Mar 23, 2006 10:15 AM
NJDiverDan
Mar 19, 2003 06:46 AM
Extreme Diesel
16
Nov 29, 2002 06:14 AM
