Round bale hoops?
Old Dec 16, 2002 | 04:57 PM
dodgeman01's Avatar
Round bale hoops?
We own a cattle farm and I was wandering what the best Round bale hoop was. What metal would work the best?<br><br>This is pointed more to Cattle Hauler but I figured someone else might have some info.<br>Thanks<br>Aaron<br>DM01
Old Dec 16, 2002 | 06:38 PM
rich's Avatar
Re:Round bale hoops?
Powder River I think makes a pretty good one or you can use round tubing to make one probably easier to buy one. Tractor Supply usaully sells them if ther is one in your area.
Old Dec 16, 2002 | 06:44 PM
dodgeman01's Avatar
I have tried those but with all the acid in cow poopiee they rust out fast. I was looking for one that would resist rusting but be strong. We have one that we got for free and has lasted for 6 years. I think it is made out of used Durajunk heads <br>DM01
Old Dec 17, 2002 | 12:42 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
We use cheap square tubing ones that I painted before stuffing out in the corrals. Going on 7 years now, and as long as you take the time every couple of weeks to pull it out of the built up waste hay, they stay in good shape.<br><br>We only feed calves in round feeders these days. The cows get fed in fenceline feeders that I pile hay in front of and push the bales into the feeder once every couple days. Much less waste as the cows tend to stand with their heads in the feeders versus grabbing a mouthful and backing out.<br><br>Rod
Old Dec 17, 2002 | 12:57 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I read in the paper today some bad new's for you guys that work cattle for a living.<br> Seems the Govt. is going to ban those round bales of hay because of a study they did on them. The multi million dollar study came to the conclusion that because of ROUND bales of hay, the cattle are simply not getting a SQUARE meal anymore. : ;D
Old Dec 17, 2002 | 12:59 AM
dodgeman01's Avatar
<br><br><br><br><br> <br>DM01
Old Dec 17, 2002 | 05:54 AM
PistolWhipt's Avatar
Top was the only little kid to ever put the square peg in a round hole. ;D ;D<br><br>PISTOL
Old Dec 17, 2002 | 06:17 AM
bulthisl's Avatar
There used to be an old man that made them and sold them through Southern States around here. They are made from some type of oval tubing. I bought 3 three of them either 14 or 15 years ago and other than a little of the paint is gone , you can't tell that they are hardly used at all.<br>I don't pull them out in the summer and get them off the ground.<br>I payed about half again as much for them when I bought them but it was worth it.<br>You get what you pay for.<br><br> : Eddie : 8)
Old Dec 17, 2002 | 09:18 AM
me4osu's Avatar
We just bought a new one made of galvanized tubing. It is easy to stand up and roll over the bale. The main advantage is that the cows can push it around to get the hay in the middle. <br><br>We used to have one made of angle iron and the angle tended to dig in as the cows tried to push it around to get the last of the hay. When it dug in, it would get all bent up.
Old Dec 17, 2002 | 09:23 AM
Fishcop's Avatar
Atta boy Top.......
Old Dec 17, 2002 | 01:45 PM
Admin Team Leader
[quote author=PistolWhipt link=board=10;threadid=8402;start=0#81280 date=1040126073]<br>Top was the only little kid to ever put the square peg in a round hole. ;D ;D<br><br>PISTOL<br>[/quote]<br> That's Right! I hate to conform with all those other non-conformist! ;D
Old Dec 17, 2002 | 06:46 PM
dodgeman01's Avatar
<br>We have one of those that was given to us and that is what i'm looking for. There is a problem thye are no where to be found around are parts. We called Tractor supply and others but still we can't find them. <br>Where do you get yours? How much?<br>Thanks<br>Aaron
Old Dec 18, 2002 | 10:03 AM
sdgunslinger's Avatar
If you feed enough cows to consume at least one bale a day , I would try Cattle Haulers method . That's the way I do it and there is little waste , certainly as little as any way you can feed round bales short of grinding it all and feeding in a bunk .
If the bale is really round and tight you may not even need to push it with your tractor . I set them up on a big sidehill if the weather is not bad , cut the twine if it is still good and give it a push . You have to unroll the bale the same direction it was rolled up and it works slicker than deer guts on a pump handle ............ HehHeh
Old Dec 18, 2002 | 10:12 AM
cr1998's Avatar
Not trying to throw the thread off course, but I thought this was going to be about some new basketball game on the farm. Round Bale Hoops. ;D
bigredbrick
Jan 5, 2014 08:51 PM
04ctd
Dec 6, 2010 07:06 PM
cairo glenn
Mar 15, 2007 04:26 PM
crobtex
Aug 16, 2006 12:20 AM
Herrin811
Oct 10, 2005 10:29 PM
