Piston Pics
Old Feb 12, 2007 | 10:01 PM
QWKRTNU's Avatar
Piston Pics
This is in a gasser. The first few are the one in question has a little pitting. The one called frontgoodone is what all the other pistons look like. What do you think? Should I rebuild it now or change the one out or go with it. thanks
Please find somewhere more family friendly to host your pics
Old Feb 12, 2007 | 10:10 PM
bigwhite59's Avatar
i would pull it and at least check it for cracks, it looks like that cylinder was pinging/running lean. you might be surprised to find a ring land cracked. what was the reason for originally pulling the head? did you run a compression test/ flowby test before pulling the heads? If you've got the motor out of the car already, i'd at least inspect it at the cost of some gaskets. Just be sure to keep rod bearings/crank bearings in order so you can reinstall them where they came from if you decide everything looks ok.
Old Feb 12, 2007 | 10:12 PM
QWKRTNU's Avatar
Its got 2 psi lower compression and I pulled it because I blew the head gasket.
Old Feb 12, 2007 | 10:17 PM
dj_souvlaki's Avatar
hows the cylinder wall look?
just incase i would pop it off and take a quick peak.
Old Feb 12, 2007 | 10:19 PM
QWKRTNU's Avatar
Looks fine. The motor is still in the car that is the problem. I realy dont want to rebuild it right now. But if I have too I will. Its got 84000
Old Feb 12, 2007 | 10:20 PM
what kind of car is this?
Old Feb 12, 2007 | 10:21 PM
QWKRTNU's Avatar
84 Buick Grand national
Old Feb 12, 2007 | 10:24 PM
sa far as i know those are pretty solid engines.
how does the oil look? any coolant get in there or was it just an external head gasket leak?
Old Feb 12, 2007 | 10:25 PM
QWKRTNU's Avatar
Just an external one. I plan on rebuilding it but wanted to see how far I could take this one till I saw it
03 Melt Down
Jun 12, 2013 05:31 PM
Bobcat698
91
Nov 3, 2007 03:19 AM
CTD99
13
Aug 23, 2005 10:55 PM
thumper 549
Sep 28, 2003 09:29 PM
