Ooops
Old Jan 13, 2007 | 07:51 AM
signature600's Avatar
Originally Posted by JKM
and excavator would never have a hope in this world of lifting that, and you can't dig a hole there to put the truck under it , because it would have to be a fairly large hole to get the truck down far enough , and at the right angle to keep from high pinning the trailer, there is also a water main under there.
You don't dig a hole to back the truck into...you dig out the trailer, then drag it out of the way with the wrecker or excavator (if it's big enough)
We had one of a local farmers drivers do that with a loaded grain trailer one fall, it was dry when he left, but we got dumped on that night. Next morning his boss handed him a shovel and told him to fix it! They still call him "Booboo"
Chris
Old Jan 13, 2007 | 08:04 AM
pappyman's Avatar
I use to have a towing company and have been on many call outs to lift trailers that sank and buried the landing gear.....it takes awhile because the landing gear pads will hang up while lifting the trailer....the worst one was a trailer loaded with coils of steel the driver missed the concrete landing pad and when he unhooked he took off all the loading chains and binders so no one would steal them as the trailer sank the coiled steel rolled to the nose so all the weight was on the front at one point my wreckers front wheels where 2 ft off the ground
Old Jan 13, 2007 | 09:15 AM
PourinDiesel's Avatar
Can you get a picture of the cluster when they try to get it out.
Old Jan 13, 2007 | 09:24 AM
TIMMY22's Avatar
a big payloader with heavy chains...
pick it up, slide some wood under the legs. let her down and hook it up.
i would not do any digging.
can't roll it ahead without air!
good one though, yea see if you can watch what they do.
Old Jan 13, 2007 | 09:31 AM
spitfire9137's Avatar
A big wrecker could drag it, but they would most likely cage the brake chambers.
Old Jan 13, 2007 | 02:35 PM
AkTallPaul's Avatar
Originally Posted by MikeyB
Been there, done that. Had to use a Mack with a big Braden winch and a roller fairlead tail to get the trailer out.
MikeyB
I was trying to get buy not admiting to doing the same thing....but yes when I was a pup, I did it to. Had a woman on my mind an didn't pay attention...drop my trailel and when I came back, she was on her nose, cost about 400 bucks to get me out.
Old Jan 13, 2007 | 04:57 PM
JKM's Avatar
JKM
I wasn't around when they came and got it out today, but i got my father to go take some pictures.
I will post them up here after supper when i have more time.
Old Jan 13, 2007 | 09:35 PM
JKM's Avatar
JKM
Here are the pics.
Attached Thumbnails Ooops-oops-007.jpg   Ooops-oops-008.jpg   Ooops-oops-015.jpg   Ooops-oops-020.jpg   Ooops-oops-021.jpg
Old Jan 13, 2007 | 09:41 PM
I bet that was at least $200 for that wrecker to come out....
Old Jan 13, 2007 | 10:10 PM
Jim Lane's Avatar
Originally Posted by dodgeguy71
I guess that is what all the wood piled across the jack is for, to keep it from sinking to far!!
The wood pieces across the landing gear are " V Boards" and are used for tying down the load.
You put them at the top of your load and it gives you a surface for the ropes or straps to pass over and not damage the load.
Jim
Old Jan 14, 2007 | 12:31 AM
AkTallPaul's Avatar
I bet he wouldn't even start that truck for $200, thats at least a quater million dollar truck.....
Old Jan 14, 2007 | 07:14 AM
JKM's Avatar
JKM
It is also the only one in town , there are some more an hour or so from here.
I have more pictures of that truck doing it's job , it has two 300 ton winches on it.
Attached Thumbnails Ooops-dsc00223a.jpg   Ooops-dsc00224a.jpg   Ooops-dsc00227.jpg
Old Jan 14, 2007 | 11:28 AM
Hvytrkmech's Avatar
Usually takes two wreckers one on either side backed up to the front, they make a sling and lift it and the truck backs up under it and hooks up.
That is the usual method if your gonna use the cables, or you have the room on both sides of the trailer, which there is in this case. We prefer to use one of our 40 ton undereach's, just place the stinger under the frame rails then put some 6x10 oak lumber on top of the stinger, drop your stiff legs then pick it up and have the driver back under the trailer, works ultra slick, even with a fully loaded trailer, plus it is cheaper for the driver and only take about 15 min to do.
Old Jan 14, 2007 | 11:47 AM
Hvytrkmech's Avatar
Did you mean 30,000# winch's? that is an NRC body on that Freightliner and the standard boom mounted winch is a 30,000# winch. They do offer larger capacity winch's up to 45,000# on the boom but anything bigger is usually a dragline winch set on the deck.
We have 2 NRC heavy wreckers, one is a 25 ton stationary boom and the other is a 27 ton slider, one has 25,000# winch's and the other has the 30's on it.
Thanx for posting the pics.
Old Jan 14, 2007 | 11:53 AM
JKM's Avatar
JKM
Yeah , that was my bad , I got an extra 0 in there somehow , even one 300 ton winch would pull that truck right in two
