Ooops
Old Jan 12, 2007 | 03:20 PM
JKM's Avatar
JKM
Ooops
Saw this in the lot across the road from my house when I got home this afternoon. Took a drive and tried to find the driver , I figure he dropped the trailer for the weekend and went home, I was at least going to let him know before it sunk too far , the pin is almost on the ground now. . The trailer was not there when I left this morning at 6.
Old Jan 12, 2007 | 03:21 PM
madhat's Avatar
Administrator/Jarhead
Yeah... that sucks...
Old Jan 12, 2007 | 03:33 PM
jbjarko's Avatar
Oopsie! He's gonna regret that.
Old Jan 12, 2007 | 05:19 PM
Hillbilly_Deluxe's Avatar
He's Screwed If It Freezes!
Old Jan 12, 2007 | 05:46 PM
spitfire9137's Avatar
Why would you even drop your trailer there. It looks like a big mud field. Although it doesnt look like the truck or the trailer sank going in to there.
Old Jan 12, 2007 | 06:17 PM
dodgeguy71's Avatar
I guess that is what all the wood piled across the jack is for, to keep it from sinking to far!!
Old Jan 12, 2007 | 09:30 PM
JKM's Avatar
JKM
That is actually a parking lot , trucks used to park there alot , until they put up a sign dis-allowing it, he just parked way out of the way , where it was soft , normally it is not a problem.
The wood piled on the dolly legs is actually for spacing the skids of wood out (the load) so a forklift has a space to get inbetween them while un loading, those little twigs wouldn't stand a chance to holding that up.
Old Jan 12, 2007 | 09:32 PM
jbjarko's Avatar
Time to put your truck to work! Be a nice guy
Old Jan 12, 2007 | 09:44 PM
PourinDiesel's Avatar
Ok next question:
How do you get that out?
Old Jan 12, 2007 | 11:04 PM
durasmack's Avatar
Looks like somebody will be having some fun with an excavator/backhoe/wrecker pulling that back up sometime.... Do they plan to unload it there?
Old Jan 12, 2007 | 11:05 PM
AkTallPaul's Avatar
Originally Posted by PourinDiesel
Ok next question:
Usually takes two wreckers one on either side backed up to the front, they make a sling and lift it and the truck backs up under it and hooks up.
Old Jan 12, 2007 | 11:38 PM
Coming down that far it is probably going to have some damage. Most likely to the suspension, maybe even a twisted frame.
Old Jan 13, 2007 | 12:14 AM
AkTallPaul's Avatar
I doubt if it hurt it any, those trailers a built to flex quite a bit. He must have been a newbie, or in a big hurry, or had a emergency. Cant believe he didn't use that dunage to block under his dolly's. Yes if you did it right it would have worked.
Old Jan 13, 2007 | 07:23 AM
JKM's Avatar
JKM
I don't see them unloading it here , they will likely get a wrecker in to lift it , but since there is only one in the area , it will probably have to be done with one wrecker. I have seen landing gears collapse when the truck pulled out from under them in that same parking lot, and they lifted it with one wrecker from the side , but i can't remember what was on it for a load.
the driver is back , he is sitting over there in his truck as we speak , so i assume someone will be alone shortly with a solution.
and excavator would never have a hope in this world of lifting that, and you can't dig a hole there to put the truck under it , because it would have to be a fairly large hole to get the truck down far enough , and at the right angle to keep from high pinning the trailer, there is also a water main under there.
Old Jan 13, 2007 | 07:29 AM
MikeyB's Avatar
Been there, done that. Had to use a Mack with a big Braden winch and a roller fairlead tail to get the trailer out.
MikeyB
