old 20lb propane bottles
Old Jun 29, 2008 | 04:46 PM
Syndicate's Avatar
ok guys what can these old BBQ bottles be used for. I have 3-4 of em that are too old to fill now. Should I use em as air tanks on my compressor or???
Lets hear your ideas.
Old Jun 29, 2008 | 05:28 PM
Gunrunner's Avatar
Take em to one of those places that you trade in your empty one for a full one and presto, new tanks.
Old Jun 29, 2008 | 05:48 PM
Syndicate's Avatar
LOL I have enough newer tanks i can fill. I am kinda interested in using them as air tanks or ???
Old Jun 29, 2008 | 06:01 PM
mikmaze's Avatar
they work great as air tanks you could even put a pair on a separate leg of a system, fill them and then shut them off, air in case your compressor ever goes bad.
Old Jun 29, 2008 | 06:04 PM
matego's Avatar
madhat's monkey boy...
If they are too old to fill with propane why would you put 120+ PSI in them to have a bomb laying around.
Cut them in half and make flower pots for the wife. They like stuff like that made from old tires, propane bottles and tree stumps!
Old Jun 29, 2008 | 06:08 PM
DmaxEter's Avatar
They make awsome pistol and rifle targets as well!
Old Jun 29, 2008 | 06:45 PM
westcoaster's Avatar
Actually, it's not the tanks that go "bad" it's the valves on top.
If you did a bit of searching you could take them in and have them re-certified.
There is a place around here that will screw in a new valve, and do a vacuume purge and stamp the cylinder for another 10 years for around $15
Old Jun 29, 2008 | 07:01 PM
1KhakiMegaCab's Avatar
Cut them in half , paint them with some high heat black pint and make a bar-b-q.
Old Jun 29, 2008 | 07:14 PM
pind's Avatar
They also make excellent reservoirs for small hydraulic systems. take out the valve, add the appropriate pipe fittings, clean them out good, and there you go.
We have used them for oil reserve on 1 ton dump decks for years.
Old Jun 29, 2008 | 07:17 PM
badme's Avatar
They make good scrap at $200+ a ton. Thats where all the ones I get go
Old Jun 29, 2008 | 07:55 PM
Bark's Avatar
Before scrapping em, punch holes in em (like DmaxEter said).
Old Jun 29, 2008 | 08:00 PM
Syndicate's Avatar
It would be cool if you could use them to suck oil or tranny fluid out the dipstic tube. Not sure how to creat enough vaccum in one though.
Old Jun 29, 2008 | 08:18 PM
matego's Avatar
Ohhhh, I thought they were bad from rusting out. They would make a pretty hoss portable air cylinder. If you got enough of them you could take them out to the ocean and raise old ship wrecks. A couple of zip ties and 100 or so cylinders and I bet you could get a Bayliner off the bottom. You could take a few of the little green ones and make a SCUBA tank. The possibilities are endless!
Old Jun 29, 2008 | 08:36 PM
93w250's Avatar
Combination air tank / Cheetah inflater.
Old Jun 29, 2008 | 09:30 PM
DmaxEter's Avatar
Thats the best idea yet. Anyone that does tire work knows what that is and what a new one costs. Good job!!!
